Monitor refresh rate jumps between 124 and 144 while capped at 140.
Posted: 16 Sep 2020, 10:00
by Unken
I have g sync and v sync on in nvidia and capped my fps to 140 in game but my monitor refresh rate still goes up to 144 and all the way down to around 124 even though Im able to play with stable 200+ without a cap. The switching is happening within milliseconds. Is this normal?
Re: Monitor refresh rate jumps between 124 and 144 while capped at 140.
Posted: 16 Sep 2020, 14:11
by jorimt
Unken wrote: ā16 Sep 2020, 10:00
If you have a G-SYNC Compatible FreeSync display, and you're talking about the built-in refresh rate meter, those are infamously unreliable.
You can try this system-side readout instead:
https://forums.guru3d.com/threads/does- ... st-5823497
Posted: 16 Sep 2020, 14:48
by Unken
jorimt wrote: ā16 Sep 2020, 14:11
Ah okay, yea that program shows a pretty stable 140 fps. Thanks!
