How do I setup Gsync with a 60hz locked game?
Kokonoe
Post by Kokonoe » 24 Oct 2020, 21:39
So this is a Gamecube game being played on Dolphin emulator. This game is Smash Bros Melee which is always 60FPS. My display is also 60hz.
Is there a way I can use Gsync with this? Thanks.
Re: How do I setup Gsync with a 60hz locked game?
Post by jorimt » 24 Oct 2020, 21:47
Kokonoe wrote:
24 Oct 2020, 21:39
Since that game's framerate is tied to engine logic, a 57 FPS limit probably won't work, no. G-SYNC would work on a higher refresh display at a locked 60 FPS though; I have a 144Hz display, for instance, and I use G-SYNC with 60 FPS games in Dolphin.
Look into RTSS Scanline Sync and other low-lag V-SYNC-only methods here:
https://blurbusters.com/howto-low-lag-vsync-on/
Displays: Acer Predator XB271HU / LG 48CX OS: Windows 10 MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA RTX 3080 FTW3 UG RAM: 32GB G.SKILL TridentZ @3200MHz
Kokonoe
Post by Kokonoe » 24 Oct 2020, 22:40
jorimt wrote:
24 Oct 2020, 21:47
Kokonoe wrote:
24 Oct 2020, 21:39
Ah okay thanks. Shame RTX 2080 Ti didnt support HDMI 2.1. I'll try to find some kinda converter.
Post by jorimt » 25 Oct 2020, 09:26
Kokonoe wrote:
24 Oct 2020, 22:40
What do you mean by that?
I was only referring to the fact that if you play a locked 60 FPS game at 60Hz with G-SYNC, that it won't keep it in the G-SYNC range, and will thus revert to V-SYNC behavior with G-SYNC on + V-SYNC on or V-SYNC off behavior with G-SYNC on + V-SYNC off.
And since Smash's framerate is tied to engine logic, the usual -57 FPS recommended limit to keep G-SYNC in range at a physical 60Hz would put the game into slow-mo, thus you should try low lag V-SYNC methods instead, as to keep the FPS nearer 60.
If you had a higher than 60Hz G-SYNC-supported monitor though, you're 2080 Ti would suffice for purposes of a locked 60 FPS G-SYNC at 100Hz, 120Hz, 144Hz, 240Hz, etc, HDMI 2.1 or no.
