Settings for clearest 240Hz blur reduction mode on aw2518h
Moushady
Post by Moushady » 28 Oct 2020, 04:08
Hi,
I just got my alienware 240hz aw2518h, but the monitor feels like there is motion blur on it and not as clear picture as my xl2411.
If someone can help me to make the picture more clear like using the fast response time without getting that ghosting trail it would be appreciated.
Also i would like to know how to use CRU for best competitive edge on this monitor.
Thanks in advance :D
Re: Settings for clearest 240Hz blur reduction mode on aw2518h
Post by Chief Blur Buster » 28 Oct 2020, 19:44
Do you prefer strobe-based motion blur reduction (e.g. ULMB), or framerate-based motion blur reduction (e.g. brute framerate & Hz)?
If you prefer strobeless blur reduction -- we prefer absolute minimum 2x refresh rate upgrades, i.e. 60Hz->144Hz, or the 144Hz->360Hz upgrade, since you need to double refresh rate to halve display motion blur (for framerate-based motion blur reduction).
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
TTT
Post by TTT » 02 Nov 2020, 09:43
Thats how the first gen 240hz are.
In comparison to the upgraded 240hz and other 144hz they are laggy panels.
Also the picture does look a bit fuzzy and soft all the time, you need to use Nvidia image sharpening to make it clearer.
wiraxbox363
Post by wiraxbox363 » 09 Nov 2020, 18:50
So there is no noticeable improvement over 144hz 4ms to 144hz 1ms monitor?
