I have a gt72 dominator pro g 6qe MSI gaming laptop that has 75HZ G-SYNC ready? screen
After a minor video card upgrade (gtx -980m 4gb to the 8gb version)
And a bios update along with the geforce driver updates
G-SYNC DISAPPEARED after this the option is not even available on control panel and now its only 60hz
Confused since apparently g-sync is not available in the 980?
But then how come i could use it before?
Very mysterious
Will try to roll back drivers right now the monitor driver says its standard pnp monitor, or roll back the NVIDIA drivers i dunno
Or was i totally scammed by MSI?
Lost g-sync and screen switched from 75HZ to 60hz
Re: Lost g-sync and screen switched from 75HZ to 60hz
Have you just updated the geforce drivers or did you do a full DDU clean install?
If you only updated, get DDU and do a full wipe and clean install of the latest driver.
