Is anyone else who owns the modified VG248 getting this sometimes, maybe every couple of days, when the monitor is turned on?
http://i.imgur.com/eeasUjW.jpg
It does this until it's unplugged from the wall and turned on again...
Here's the firmware, just incase ManuelG_NVIDIA is reading this:
http://i.imgur.com/FPWYCpF.jpg
Glitch with the G-sync monitor. No input detected
- fenderjaguar
- sharknice
Re: Glitch with the G-sync monitor. No input detected
This happens all the time to me, usually if I turn my monitor on before my computer. Just press the menu button (or any other button) and it goes away.fenderjaguar wrote:Is anyone else who owns the modified VG248 getting this sometimes, maybe every couple of days, when the monitor is turned on?
- fenderjaguar
I'll try that next time. Thanks
I think I was just turning the monitor off and on, and it didn't seem to get rid of the message.
CoMa
So it's this kit bugged or a sure buy?!
- sharknice
It's fine, the no input detected bug is the only one I know of. You just press the menu button twice and it is fixed. A very minor annoyance at the most.CoMa wrote:So it's this kit bugged or a sure buy?!
- fenderjaguar
OK, next glitch. Also a very minor one.
I have the desktop in ULMB 120hz mode all the time, because it's dimmer. Sometimes, not very often, about as often as the first glitch, the whole image shifts roughly about 5 or 10 pixels up the screen:
http://i.imgur.com/Ka0YWOu.jpg
http://i.imgur.com/MCzzsAk.jpg
It does this until you hit the ULMB button again...
