Watching video with G-sync, windows 10, actual 2021 setup.
wenarlin
Post by wenarlin » 04 Nov 2021, 09:27
The setup is pretty simple
First Download and install mpv player to c:\prog\mpv
Then create file "mpv.conf" in c:\prog\mpv\mpv and open it with notepad and paste this to it:
Code: Select all
--video-sync-max-factor=1
--video-sync=audio
Then watch you videos with g-sync in fullscreen mode(press the F button)
Windowed g-sync unfortunately have glitchy FPS fluctuations
Have fun!
My actual setup is:
mpv-x86_64-20211031-git-4a80de9 is actual version Im used for g-sync playback
Nvidia drivers 496.49
gtx 970 videocart
pg279q 165hz monitor with hardware g-sync module
pg279q, 4790k, asus m7h, gtx970, 16gb RAM, asus xonar DGX
Re: Watching video with G-sync, windows 10, actual 2021 setup.
Post by Chief Blur Buster » 04 Nov 2021, 10:09
Thank you for such a useful tip!
Justnpy
Post by Justnpy » 27 Jan 2022, 14:22
does it appear to you making a difference in watching videos ?
i asked this myself far to often now while watching videos in g sync i even interpolate them to archive higher refresh rates and smoother output.
Post by RealNC » 28 Jan 2022, 09:52
Justnpy wrote:
27 Jan 2022, 14:22
I don't know about interpolation, but it makes a difference when the video's frame rate can't be mapped 1:1 to the display's refresh rate. If you use 120Hz on your monitor, then g-sync is not that important, because 24FPS, 30FPS and 60FPS videos map perfectly to 120Hz. But for 25FPS and 50FPS video, it doesn't, so you would either need to use 100Hz mode, or use g-sync.
Basically with g-sync you don't have to care anymore what the video's frame rate is.
alberto91
Post by alberto91 » 17 Feb 2022, 01:46
Thanks for this fascinating thread. I will surely these tips.
wenarlin
Post by wenarlin » 09 Jan 2023, 07:23
Just poking the thread to top. It is actual for now.
