Starcraft 2 and G-sync
I can't active G-sync with starcraft 2 can someone help me?
Re: Starcraft 2 and G-sync
Your Starcraft 2 might be running in full screen windowed mode. GSYNC doesn't work in windowed mode (even when it's a full screen borderless window).
However, NVIDIA showed off Starcraft running GSYNC at BlizzCon running GSYNC, so there is a way to make it work. Find out if you can switch away from this mode -- some games have different "Fullscreen" settings, and you need to go to a true full screen mode in order for GSYNC to work.
Did you try forcing GSYNC via the override?
I did it, and i know sc2 works with G-sync but really mine don't active!
It's works with all games but not with sc2... i really dunno how to do...
Set it under program settings too. If that doesn't work sometimes you just need to restart your computer and try again.CoMa wrote:I did it, and i know sc2 works with G-sync but really mine don't active!
Some games want to run in maximized window mode, rather than as a true windowless full screen app. GSYNC is incompatible with windowed mode, even if maximized. See if Starcraft has a setting for this.
Is there really absolutely no way to get g-sync without full screen, cause that might very well be a deal breaker for me
Up until reading this I was seriously looking forward to that ASUS 1440p 144 Gsync screen.
I constantly multitask and love it when games offer fullscreen windowed mode.
Ideally whatever is in the foreground would control the refresh-rate, or even leave whatever refresh rate the game was last/still using.
In SC2 options, it's say it's fullscreen... how i can see if it's true?
I restarted, and nothing it's full screen, Diablo3 works....
