VPixx Propixx first tests?
valfranx
Post by valfranx » 08 Oct 2014, 09:04
Resolutions
Supported resolutions:
1024*768@240Hz
Just to let you know the projector is working fine with these settings now (although I have put them back to the usual default native settings), for the sync tests and the perceptual tests, cool no!! I think 240Hz is about as much as we want these days I suggest that we do not update the firmware for the time being, although I have asked Peter April Vpixx CEO to send me some scripts to run the 1440Hz greyscale image, but for this we do not need to change the firmware.
The crucial things is this:
Whenever changing the screen resolution both the Proprixx Crontroller (Little Blue Box) and the Propixx projector **MUST** be plugged in via their respective USB cables.
We are currently running r29 of Proprixx Crontroller (2nd June 2014) and r10 of the Propixx projector.
https://wiki.cimec.unitn.it/tiki-index. ... e=MEGVPixx
