I have little to say on this subject so mostly I'm just throwing the idea out there with a question: with the broad latent demand for hi-speed imaging (FPS gamers to advanced GUIs to VR to UHDTV) shouldn't there be an organized community to, well, organize the demand for this technology? There is activity in the mod/hack community and some display makers are slowly introducing hi-speed input models but nothing really seems official, or enforcing minimum standards, hence HDMI 2, or planning for the future. Hi-speed displays should get the same Retina-quality fanboi treatment from the marketplace that Retina / Super Hi-Vision (to use NHK's meme-tastic UHDTV terminology) displays do.
Does anyone else think it's time for a serious attempt at organizing an open standards project for "Super Hi-Speed" to go along with "Super Hi-Vision" UHDTV and Retina displays?
Create an Open Standard -- for Hi-Speed Imaging & Display?
An open standardization for high-Hz displays?Neo wrote:I have little to say on this subject so mostly I'm just throwing the idea out there with a question: with the broad latent demand for hi-speed imaging (FPS gamers to advanced GUIs to VR to UHDTV) shouldn't there be an organized community to, well, organize the demand for this technology? There is activity in the mod/hack community and some display makers are slowly introducing hi-speed input models but nothing really seems official, or enforcing minimum standards, hence HDMI 2, or planning for the future. Hi-speed displays should get the same Retina-quality fanboi treatment from the marketplace that Retina / Super Hi-Vision (to use NHK's meme-tastic UHDTV terminology) displays do.
This is an excellent suggestion, and Blur Busters would be happy to be behind such an effort.
I have experience writing industry standards that gets accepted by an organization:
http://www.xmpp.org/extensions/xep-0301.html
XMPP: In-Band Real-Time Text (by Mark Rejhon), illustrated animations at http://www.realjabber.org
It may be a bit too early to start a standards initiative, and I need to grow a little bit more industry pull (even as ASUS, BENQ, NVIDIA has begun paying serious attention to Blur Busters). However, I am well positioned to help contribute to an industry standardization for computer/gaming-friendly low-persistence and high-Hz displays. Our tests show that even 1000Hz is not the final frontier, and not everyone at ASUS/BENQ quite realizes this. See post Need 1000fps at 1000Hz to achieve 1ms persistence without using strobing.
At the very least, I would very much to start a standardization of response measurement. I want displays to report response measurements in persistence, not just GtG/transition. Chiefly because most 1ms/2ms LCDs still have 16.7ms of persistence, and persistence is THE cause of display motion blur, not GtG/transition (proof: www.testufo.com/eyetracking).
Re: Create an Open Standard -- for Hi-Speed Imaging & Displa
Thank's for cleaning up the subject line.
Yes, that's where I see the current situation: evangelism and building activist consumer demand so industry hears it.Chief Blur Buster wrote: It may be a bit too early to start a standards initiative, and I need to grow a little bit more industry pull...
Maybe even a new buzzterm is needed. "Effective frame" or something that measures the actual image light delivered to the eye, as well as it's quality (gamma, chroma, flicker etc.)At the very least, I would very much to start a standardization of response measurement.
