[tachitoscope] How to show a pic for exactly 12.5ms?
Advanced display talk, display hackers, advanced game programmers, scientists, display researchers, display manufacturers, vision researchers. The masters on Blur Busters.
calliefrance
Post by calliefrance » 28 Aug 2019, 03:50
Basic Guide In Post Card Printing For Beginners
Door Hanger printing refers to firms that will print up door hangers to advertise your business. Get arthritis after breaking use the internet to promote their business.And test? The internet is the place where most people go to locate a product or an app. But people in business are forgetting about the grass roots advertisingthat people relied upon before the internet revolution.
visit website: https://twitter.com/inanazhanoi/status/1156776833712394241
I'm ' speak for the Twenty-one Bomber Fans when I say that If only for the speedy recovery of Pete "Foots" Gratta, and expect to his return back behind the glowinggreen Black Jack Bomber drum kit.right where he fits in!
During this time, Thomas last many of his finding out. As a child he any fight with scarlet fever, and many untreated ear infections. It is claimed that part for this reasonfor his hearing loss is web site conductor boxed his ears after his fire typically the baggage car. Later Thomas said, the injury happened each and every conductorlifted him by his ears, while helping him onto a moving train.
read more information: https://inanaz.com.vn/chat-lieu-in-card-visit.html
Secondly, you'll find printable coupon codes. With these, you should have a paper copy and gives it all of the retail outlet at see. These may come as coupon publications.Another source is printing them directly online. They will not work a person try all of them on websites when testing.
If you have the leisure of time, it may well worth to give it a shot. Sometimes anyone thought impossible the period around is considered plausible after you havea go.
That is mainly because it is engineered with a plastic lip that extends into the bottle to be sure that when the bottle is tipped to pour the purified contents into yourwater bottle that the crystals get surrounded. Once they are trapped behind the plastic lip you must not to be able to worry with losing your iodine deposits. Thecap among the Polar Pure bottle is earned to fit tight and lock into position so to provide a no worry of sill. I literally fill the Polar Pure bottle and toss it in thezip top of my pack and start hiking, xbox never been a leakage.
my article: in card visit gia re
What do you find yourself waiting after that? Possess a stroll about, explore for the most reliable printer available and have your picture in newspaper. And add itfor your stuff or have it as a gift ideas. Anything you wished would do.
Post by Chief Blur Buster » 02 Sep 2019, 21:22
Hello!
This thread should in the Area 51 Display Science, Research & Engineering Forum, so I have moved this thread there.
Firstly, one needs to understand how LCD Monitors refresh, see high speed videos at http://www.blurbusters.com/scanout ... You will realize that there is a massive unfortunate error margin that makes what you want to do impossible without monitor modification because
(A) Not all pixels refresh simultaneously and synchronously.
(B) Because of pixel response, each pixel "fade in and out". This is the GtG pixel response time.
(C) Pixel changes can only be done at granular refresh intervals, dictated as the refresh rate.
You need to concurrently solve (A)(B)(C)
You can solve (C) by creating a custom refresh rate that uses refresh rate of (1000ms/target). For your case, (1000ms/12.5ms) = 80 Hz, creatable using custom resolution utility.
You can solve (A) and (B) by obtaining a blur-reducing strobe-backlight monitor, but most only have adjustable flashes from ~0.25ms to ~2.00ms. In many of them, the pulse width is independently adjustable though, so as long as you use a refresh rate higher than target, it can be doable if within the common range of 0.25ms to about 2ms.
You could use software-based black frame insertion but you won't be able to fix (A), unless you only use a tiny horizontal strip in the middle of your screen as a crude workaround -- and you will still have (B) as the error margin (pixels fading in and out when you flash). 1ms GtG, 5ms GtG, etc. Pixel response is an error margin in your case.
Your requirement of 12.5ms is a problem for off-the-market solutions; you likely will have to open up your screen.
Your last option is to probably open up the monitor and wire a custom circuit to the monitor's backlight.
Basically a trigger wire that will turn on the LEDs upon receiving a signal from an Arduino or Raspberry PI or similar circuit.
Once the screen hardware is modified to allow an Arduino to turn on/off the illumination, do as follows:
1. Continuously display image (in total darkness)
2. Wait at least a few milliseconds, but preferably for multiple refresh cycles (in total darkness) to allow LCD to finish fully transitioning the image.
3. Use an Arduino to turn on the backlight or edgelight for 12.5ms ...and then off
This eliminates pixel response from being an error margin, since the panel is refreshed in the dark before you flash the backlight (edgelight) which is LED based and practically instantaneous.
Marc Repnow of Display Corner could help you build a tachitoscope.
https://display-corner.epfl.ch/index.ph ... scopeSetup
Also, out of curiosity — why exactly 12.5ms? If you follow Tablot-Plateau law, a 125 microsecond flash 100 times brighter, will also be equally visible to a human. It’s simply equal number of photons crammed into an instant. For all sufficiently short flashes — Brightness times flash length makes all flash length look equally instantaneous and equally bright. Photo flash bulbs for cameras are still seen even if they flash less than 1 millisecond because they are super bright when they flash.
Also.... Make sure to verify experiment design includes the flash brightness variable: Same as steady state? And are you flashing black-image-black, or flashing grey-image-grey, with grey representing average picture brightness level? These variables can affect certain experiments.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
