BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
I managed to achieve 260Hz 1280X720 on the BenQ XL2411P with DP
bro i want to know which firmware do you use and the exact steps you did to make it work because it gives me out of range notification for few seconds then screen turns black
V2 or V3 fw is required.
Update is only possible via DVI monitor port. You can buy a cheap HDMI/DP to DVI adapter from amazon if your graphics doesnt support DVI. Then you'll need to use linux enviroment (live usb would go) to run flashrom utility. I can get you the compiled flashrom I have, so you could just "chmod -x" the executable and proceed to flashing.
Let me know if you need the files.
Can someone reply a guide how to overclock xl2411p to just 190-200hz, appreciate it!
Oh wow -- that's one of the most glitch-free 260Hz overclock of a 144Hz BenQ.
No frameskipping at www.testufo.com/frameskipping ?
