Acer XB272 240hz can't do custom 75hz custom resolution
Re: Acer XB272 240hz can't do custom 75hz custom resolution
Post by Chief Blur Buster » 26 Jan 2018, 14:07
BlazeGaming wrote:Yes you are right, I managed to make NVIDIA surround work on 75 hz by using the EDID from 75hz monitor on the 240hz but the monitor goes out of range. I guess I am stuck with 60hz surround.
Ugh, that is no fun.
I wonder how overclockable the 75Hz monitors are. I've seen stranger things happen before (75Hz displays that overclocked to 100Hz+). Maybe try the VT1500 mode on them anyway?
Though Exercise: If only we could view a venn diagram of all possible custom-modified 75Hz timings where the exact same CRU settings worked on all 3 monitors... I wonder if there's any overlap! Probably a longshot (<10% chance)
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
lexlazootin
Post by lexlazootin » 26 Jan 2018, 21:01
Chief Blur Buster wrote:lexlazootin, it works on your 240Hz GSYNC?
Yep, as i replied to my thread viewtopic.php?f=2&t=3490&hilit=XB252Q as long as the HT is left alone and the PixelClock is between 230 - 240 you can adjust the VT and Freq to get what ever you want ;)
