Problem with sony XE9005 (X900E) series
AnderITA
Post by AnderITA » 14 Nov 2018, 12:16
Hello there and first thank's for your time!
I have a little big problem with the screen model on topic and it is simple: a flicker" randomly appears on every HDMI port, it's most noticeable when surfin web or read a pdf or, for another sample in iTunes. A sample of this can be viewed here: https://youtu.be/nKwWzMq0aw8. Already I test it in this new one send by sony for replacement: before that in the old one, a technician come to my house and try to change first the mainboard then the inverter board" with no success… I try all resolution and ports, now run at 1920x1080 120Hz by nvidia ge force 840M (forced resolution) and the problem seems to be most rarely noticeable but present… many other user experience it but the mostly didn't apparently solved that or vanish; if any good guy have an opinion I'd like to read it, for the present and for the future… thank yoh! Ander
P.s: sorry if find any grammar errors! :)
Re: Problem with sony XE9005 (X900E) series
Post by RealNC » 22 Nov 2018, 09:48
Well, thanks for letting us know, I guess :)
AnderITA
Post by AnderITA » 23 Nov 2018, 12:18
RealNC wrote:Well, thanks for letting us know, I guess :)
sorry for boring you! no one in three months of web searches seems to have solved this problem; if an administrator considers my post irrelevant or not pertinent I kindly ask for the closure thanks
AnderITA
Post by AnderITA » 24 Nov 2018, 09:04
Frame Skipping test
https://ibb.co/i2D9SA
Post by RealNC » 25 Nov 2018, 10:11
It's not a boring post, nor off-topic. It's helpful to everyone who finds it through google search. When I said thanks for letting us know, I wasn't being sarcastic or anything :)
Post by Chief Blur Buster » 27 Nov 2018, 00:11
Posts like these are welcome on Blur Busters :)
Sometimes we don't always have something to add -- but this is useful reading for experience with future monitor issues.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
AnderITA
Post by AnderITA » 11 Oct 2019, 09:13
Chief Blur Buster wrote:Posts like these are welcome on Blur Busters :)
Thank you Chief; nothing has change, the problem" persist also with new gpu system. Can't do nothing about it... I noticed in yours test called Inversion Artifacts set in uniformity extended mode that the image flicker also in pause" is it normal? I ask you because the random flicker/refresh or defect is at my eyes the same effect". Thanks for your time. Andrea
