BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
hleV
Post by hleV » 18 Jul 2019, 10:30
Can also confirm XL2411Z DVI overclock: 1080p 210Hz with 0xCC and 0xDC (good info from urut) activation.
Used ToastyX Pixel Patcher.
Will check for frame skipping at a later time.
CSGO fullscreen plays fine (until you minimize or quit it).
Note about 0xDC:
It makes you choose a color profile, but you only get 2 options: standart and movie. Will have to see if other/custom modes are somehow available to be chosen.
BenQ XL2411Z
Post by Chief Blur Buster » 18 Jul 2019, 11:56
Excellent!
Brightness / Contrast / Gain / Etc can be used to reproduce Movie Mode or create a different mode (using more adjustments).
In this case -- Movie Mode is just essentially a quick profile to automatically configure multiple settings. Movie Mode is just a quick way to fix the 200Hz/220Hz colors (along with resetting Sharpness and AMA). I had found that it improved 220Hz colors, in the easiest/fastest way. But you can also use conventional color calibration with all the other settings.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Stalast
Post by Stalast » 18 Jul 2019, 18:20
I couldn't get this to work unfortunately on my XL2411Z via DVI, not even 145Hz. After getting the 'Out of range' message and pressing "OSD language - 0xCC" -> Activate, the Out of Range message goes away, but the screen is just black. Uploading a youtube video right now with a demonstration of what happens and will link when it's processed!
Post by Chief Blur Buster » 18 Jul 2019, 20:05
Stalast wrote:I couldn't get this to work unfortunately on my XL2411Z via DVI, not even 145Hz. After getting the 'Out of range' message and pressing "OSD language - 0xCC" -> Activate, the Out of Range message goes away, but the screen is just black. Uploading a youtube video right now with a demonstration of what happens and will link when it's processed!
1 -- Did you disable motion blur reduction before overclocking?
2 -- What firmware version are you using?
3 -- Are you using Instant Mode? Overclocking only works with instant mode.
hleV
Post by hleV » 18 Jul 2019, 23:49
Stalast wrote:After getting the 'Out of range' message and pressing "OSD language - 0xCC" -> Activate, the Out of Range message goes away, but the screen is just black.
For XL2411Z DVI, you must Activate 0xDC after activating 0xCC to get rid of black screen:
Chief should probably edit the 1st post to reflect that.
BenQ XL2411Z
Post by Chief Blur Buster » 19 Jul 2019, 01:18
That's interesting!
On my XL2720Z, I only needed to do 0xCC.
Appears you have to do both 0xCC and 0xDC with the XL2411Z DVI.
I've updated my instructions.
Vechs
Post by Vechs » 19 Jul 2019, 05:17
Status update : Xl2420G works with 210hz, (DVI) After 210hz, the screen either blanks out or has a black screen.
Also a small thing i have noticed, sometimes I don't have a "Out of range" error, but sometimes it just shows a white screen, any tips/suggestions for that? (or thats the same "Out of range" error)
Pictures :
https://imgur.com/a/JJl6978 (the pictures look kinda strange, any suggestions on that or i need another camera for that?)
Ninja edit: The overclock is unstable, the screen does whiteout. Will try lowered hertz, currently at 200hz
Stalast
Post by Stalast » 19 Jul 2019, 08:49
This did the trick! Thanks a lot.
I tried 155Hz, looks great and no frame skipping. Then I tried 165Hz and while there was no frame skipping, I could noticed some horizontal scanning lines that move up vertically. Does that mean the monitor is unstable at 165Hz? Proof here of frame skipping tests at 1/5th sec shutter speed and a video of the horizontal scanning lines below. YouTube compression makes it very difficult to notice the lines though.
155Hz test #1
155Hz test #2
155Hz test #3
165Hz test #1
165Hz test #2
165Hz test #3
Video of horizontal scan lines (most noticeable on grey background).
tlp
Post by tlp » 19 Jul 2019, 12:53
Tried this with my BenQ XL2411T.
The "Display Application - 0xDC" listing gets greyed out when I apply the 220hz video mode, however the "OSD language - 0xCC" works as expected and removes the "Out of range" message.
Also the monitor doesn't seem very happy whatsoever with the exact video mode from the screenshot in the original post and will turn off the backlight completely for ~3 seconds and seemingly reboot, is it necessary to mirror the custom resolution exactly from the original post or does "Automatic" work fine aswell?
I attempted 150hz and 200hz and got the same result minus the screen unhappily rebooting.
Notty_PT
Post by Notty_PT » 19 Jul 2019, 15:38
Be careful!! I have bad news. I just broke a XL2430T trying this with S-Switch method..
Everytime I connect the monitor now with Display Port, the "no signal" message appears. It doesnt work even on the bios or with another device connected. Deleted all custom resolutions, restarted everything with CRU... No luck. It works fine on other ports like HDMI. I think I broke displayPort on this monitor. And now I doubt I can return this way.
Anyone has suggestions? Chief? I'm clueless and sad..
