BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
RoadToPro
Post by RoadToPro » 04 Feb 2020, 15:58
Hi guys
im new to PC gaming and i bought a benq xl2411p for e sports
the hz is capped to 144
but my PC can easily get 200 fps
i would be happy with anything more than 144hz
but i use an AMD gpu
and i want to play Fortnite (pls don't judge)
does this guide work for me then?
thanks
is it possible to do this with a single monitor?
i only have access to my one
again thanks
Protox
Post by Protox » 04 Feb 2020, 17:54
RoadToPro wrote:
04 Feb 2020, 15:58
Hi guys
thanks
again thanks
if you read the whole topic you will surely be able to do it.
Protox
Post by Protox » 04 Feb 2020, 17:59
I have a xl2411P and i have reached 250hz on 1440x810
but i'm wondering if this oc maiby hurt on the long time.
Sorry for the bad english.
Post by Chief Blur Buster » 09 Feb 2020, 00:52
Protox wrote:
04 Feb 2020, 17:59
There is no guarantee about damage but historically, monitor overclocking tends to not have as much risk as CPU overclocking.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
ocean1998
Post by ocean1998 » 14 Feb 2020, 17:14
The link isn't working, Could you reupload the link please!!!
hleV wrote:
29 Jan 2020, 12:30
(This was posted on the wrong thread, so re-posting this where it belongs.)
In case anyone needs it, here's a slightly updated OOR Buster (V1.4). Been using it for over a week now and it seems to work well. I couldn't be bothered to upload the whole Visual Studio project to GitHub (I'm updating and compiling the code on work PC) but here's the binary:
https://github.com/hleVqq/OorBuster/rel ... Buster.exe
Changelogs:
Code: Select all
1.1
- Alt + Home hotkey added.
Code: Select all
1.2
- Added previous/next picture mode buttons.
Code: Select all
1.3
- Added monitor handle re-check for most scenarios
- Reload button now removes the Out of Range notification if present
- Removes other "OorBuster.exe" instance(s) upon launch
Code: Select all
1.4
- Fixed current monitor settings not being read before applying fix on app launch
- When removing other instances, it will check for current file name rather than hardcoded "OorBuster.exe"
- Removed initial delay when using Alt + Home hotkey
In order to start OOR Buster upon boot faster, use Windows' Task Scheduler and create a basic task:
  • Name: OOR Buster
  • Trigger: When I log on
  • Action: Start a program
  • specify path and optional params
C++ code (covers most of the program except resources code generated by Visual Studio):
Code: Select all
#include <Windows.h>
#include <tchar.h>
#include <shellapi.h>
#include <lowlevelmonitorconfigurationapi.h>
#include <string>
#include <Tlhelp32.h>
#include "resource.h"
const BYTE VCP_OSD_LANGUAGE = 0xCC;
const BYTE VCP_PICTURE_MODE = 0xDC;
const BYTE VCP_AMA = 0xF0;
enum
	WM_APP_RELOAD = WM_APP + 1,
	WM_APP_EXIT,
	WM_APP_NEXT_MODE,
	WM_APP_PREV_MODE
DWORD CachedOsdLanguage = 2;
DWORD CachedPictureMode = 0;
DWORD CachedAma = 1;
DWORD OorDelay = 2000;
DWORD PicDelay = 500;
DWORD AmaDelay = 250;
DWORD WakeDelay = 3000;
NOTIFYICONDATA TrayIcon;
HANDLE Monitor;
int GetRefreshRate()
	DEVMODE dm;
	dm.dmSize = sizeof(DEVMODE);
	EnumDisplaySettings(NULL, ENUM_CURRENT_SETTINGS, &dm);
	return dm.dmDisplayFrequency;
HANDLE GetPhysicalMonitor()
	HMONITOR monitor = MonitorFromWindow(GetActiveWindow(), MONITOR_DEFAULTTOPRIMARY);
	LPPHYSICAL_MONITOR monitors = (LPPHYSICAL_MONITOR)malloc(sizeof(PHYSICAL_MONITOR));
	HANDLE pm = nullptr;
	if (monitors && GetPhysicalMonitorsFromHMONITOR(monitor, 1, monitors))
		pm = monitors[0].hPhysicalMonitor;
	free(monitors);
	return pm;
void CachePhysicalMonitor()
	Monitor = GetPhysicalMonitor();
void CacheVcpValues()
	GetVCPFeatureAndVCPFeatureReply(Monitor, VCP_OSD_LANGUAGE, NULL, &CachedOsdLanguage, NULL);
	GetVCPFeatureAndVCPFeatureReply(Monitor, VCP_PICTURE_MODE, NULL, &CachedPictureMode, NULL);
	GetVCPFeatureAndVCPFeatureReply(Monitor, VCP_AMA, NULL, &CachedAma, NULL);
void ReadLaunchParams()
	int argCount;
	LPWSTR* args = CommandLineToArgvW(GetCommandLine(), &argCount);
	if (args && argCount > 1)
		OorDelay = (DWORD)wcstod(args[1], L'\0');
		PicDelay = (DWORD)wcstod(args[2], L'\0');
		AmaDelay = (DWORD)wcstod(args[3], L'\0');
		WakeDelay = (DWORD)wcstod(args[4], L'\0');
inline void FixOor() {SetVCPFeature(Monitor, VCP_OSD_LANGUAGE, CachedOsdLanguage);}
inline void FixPic() {SetVCPFeature(Monitor, VCP_PICTURE_MODE, CachedPictureMode);}
inline void FixAma() {SetVCPFeature(Monitor, VCP_AMA, CachedAma);}
void NextMode()
	CachePhysicalMonitor();
	CacheVcpValues();
	CachedPictureMode++;
	FixPic();
void PrevMode()
	CacheVcpValues();
	CachedPictureMode--;
	FixPic();
void ApplyVcpValues(bool wake = false)
	if (GetRefreshRate() <= 144)
		return;
	if (wake)
		Sleep(WakeDelay);
	Sleep(OorDelay); FixOor();
	Sleep(PicDelay); FixPic();
	Sleep(AmaDelay); FixAma();
void ShowTrayMenu(HWND wnd)
	POINT pos;
	GetCursorPos(&pos);
	HMENU menu = CreatePopupMenu();
	InsertMenu(menu, -1, MF_BYPOSITION, WM_APP_RELOAD, L"Reload");
	InsertMenu(menu, -1, MF_BYPOSITION, WM_APP_NEXT_MODE, L"Next Mode");
	InsertMenu(menu, -1, MF_BYPOSITION, WM_APP_PREV_MODE, L"Prev Mode");
	InsertMenu(menu, -1, MF_BYPOSITION, WM_APP_EXIT, L"Exit");
	SetForegroundWindow(wnd);
	TrackPopupMenu(menu, TPM_BOTTOMALIGN, pos.x, pos.y, 0, wnd, NULL);
	DestroyMenu(menu);
LRESULT CALLBACK WindowProc(_In_ HWND wnd, _In_ UINT msg, _In_ WPARAM wParam, _In_ LPARAM lParam)
	switch (msg)
	case WM_DISPLAYCHANGE:
		ApplyVcpValues();
		break;
	case WM_POWERBROADCAST:
		if (wParam == PBT_POWERSETTINGCHANGE)
			const DWORD DISPLAY_ON = 0x1;
			POWERBROADCAST_SETTING* pbs = (POWERBROADCAST_SETTING *)lParam;
			DWORD status = *(DWORD*)(pbs->Data);
			if (status == DISPLAY_ON)
				ApplyVcpValues(true);
		break;
	case WM_APP:
		switch (lParam)
		case WM_RBUTTONDOWN:
		case WM_CONTEXTMENU:
			ShowTrayMenu(wnd);
			break;
		break;
	case WM_COMMAND:
		switch (LOWORD(wParam))
		case WM_APP_RELOAD:
			FixOor();
			CacheVcpValues();
			break;
		case WM_APP_NEXT_MODE:
			NextMode();
			break;
		case WM_APP_PREV_MODE:
			PrevMode();
			break;
		case WM_APP_EXIT:
			Shell_NotifyIcon(NIM_DELETE, &TrayIcon);
			PostQuitMessage(0);
			break;
		break;
	case WM_DESTROY:
		PostQuitMessage(0);
		break;
	case WM_HOTKEY:
		switch (wParam)
		case 1000:
				OutputDebugString(L"[DEBUG] HOTKEY!\n");
				DWORD origOorDelay = OorDelay;
				OorDelay = 0;
				ApplyVcpValues();
				OorDelay = origOorDelay;
			break;
	return DefWindowProc(wnd, msg, wParam, lParam);
HWND CreateMainWindow(HINSTANCE instance)
	WNDCLASS wc = { };
	wc.lpfnWndProc = WindowProc;
	wc.hInstance = instance;
	wc.lpszClassName = L"Main";
	RegisterClass(&wc);
	HWND wnd = CreateWindow(L"Main", L"OOR Buster", WS_OVERLAPPEDWINDOW & ~WS_SIZEBOX & ~WS_MAXIMIZEBOX, CW_USEDEFAULT, CW_USEDEFAULT, 0, 0, NULL, NULL, instance, NULL);
	return wnd;
void CreateTrayIcon(HWND wnd, HICON icon)
	ZeroMemory(&TrayIcon, sizeof(NOTIFYICONDATA));
	TrayIcon.cbSize = sizeof(NOTIFYICONDATA);
	TrayIcon.uID = 1;
	TrayIcon.uFlags = NIF_ICON | NIF_MESSAGE | NIF_TIP;
	TrayIcon.hIcon = icon;
	TrayIcon.hWnd = wnd;
	TrayIcon.uCallbackMessage = WM_APP;
	wcscpy_s(TrayIcon.szTip, L"OOR Buster");
	Shell_NotifyIcon(NIM_ADD, &TrayIcon);
void KillOtherInstances()
	DWORD id = GetCurrentProcessId();
	WCHAR path[MAX_PATH];
	GetModuleFileName(NULL, path, MAX_PATH);
	WCHAR file[_MAX_FNAME];
	_wsplitpath_s(path, NULL, 0, NULL, 0, file, ARRAYSIZE(file), NULL, 0);
	wcscat_s(file, ARRAYSIZE(file), L".exe");
	HANDLE snapshot = CreateToolhelp32Snapshot(TH32CS_SNAPALL, NULL);
	PROCESSENTRY32 entry;
	entry.dwSize = sizeof(entry);
	for (BOOL res = Process32First(snapshot, &entry); res; res = Process32Next(snapshot, &entry))
		if (wcscmp(entry.szExeFile, file) == 0)
			HANDLE process = OpenProcess(PROCESS_TERMINATE, FALSE, entry.th32ProcessID);
			if (process != nullptr && entry.th32ProcessID != id)
				TerminateProcess(process, 9);
				CloseHandle(process);
	CloseHandle(snapshot);
int WINAPI WinMain(_In_ HINSTANCE instance, _In_opt_ HINSTANCE, _In_ LPSTR, _In_ int)
	KillOtherInstances();
	CacheVcpValues();
	ReadLaunchParams();
	HWND wnd = CreateMainWindow(instance);
	CreateTrayIcon(wnd, LoadIcon(instance, MAKEINTRESOURCE(IDI_ICON1)));
	RegisterPowerSettingNotification(wnd, &GUID_CONSOLE_DISPLAY_STATE, DEVICE_NOTIFY_WINDOW_HANDLE);
	RegisterHotKey(wnd, 1000, MOD_ALT, VK_HOME);
	MSG msg;
	while (GetMessage(&msg, nullptr, 0, 0))
		TranslateMessage(&msg);
		DispatchMessage(&msg);
	return (int)msg.wParam;
hleV
Post by hleV » 16 Feb 2020, 06:58
ocean1998 wrote:
14 Feb 2020, 17:14
https://we.tl/t-yF8K0egzvB
BenQ XL2411Z | 180Hz OC | BR off
messiaH
Post by messiaH » 21 Feb 2020, 14:35
Hey i am new to this topic and read about this overclocking method today but right now i always encounter a crash of softMCCS as soon as i try out a new resolution
messiaH
Post by messiaH » 21 Feb 2020, 17:12
messiaH wrote:
21 Feb 2020, 14:35
ok now i discovered the AntiOutOfRange-master but its either not working for me or i use it the wrong way (i change to higher hz, get out of border notification and then start the program and enter 5 seconds)
sosuyike
Post by sosuyike » 25 Feb 2020, 15:14
I have a xl2411, looking for a good setup between overclock and blur reduction, i was testing with 160 hz with blur reduction on, 2080 horizontal, 1350 vertial, pixel clock is at 449.2800mhz, but can't find a balanced compromise between clear motion / ghosting / inverse ghosting, has anyone had a go with OC and blur?
Wallhacking
Post by Wallhacking » 26 Feb 2020, 19:46
Hey, I overclocked my XL2411P to 165hz but whenever I open CSGO it uses 144hz. I tried both CRU and Nvidia control panel. CSGO just doesn't seem to run at 165 in fullscreen mode. Works fine on windowed but not fullscreen. Has anyone found a fix?
