BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
benqoced86
Post by benqoced86 » 03 Apr 2021, 21:51
Overclocking to 200hz was forcing the colours from 8bit to 6bit. I got more hz and also fps but...Don't waste your time!!!It's bad! ;)
8 vs 10
https://www.youtube.com/watch?v=NF-NamB2CUE
Benq XL2411P 144hz @ 200hz - 6 bit color is forced instead of 8 bit - more fps but less quality
F/W VERSION: V002-20170824
Force 6 bit color for more fps by editing CRU 1.5.1
rafraf
Post by rafraf » 06 Apr 2021, 03:53
Hello guys cant oc xl2411p
So first i try softmmcs with 2 screen and After with my phone when i click to occ and display app nothing happen seems like the prog doesn’t work.
After i try antioutofrange i tape 5 second for exemple and nothing happen stay in out of range.
After i try oorb v1.4 i run the programme change résolution and my screen goes out of range so i turn off my monitor and turn on after a alt+home then my screen shows half with benq logo in the middle and i must return to 144hz to fixe that, ».
I notice i have latest driver nvidia and my gpu is gtx780. Also my service page in attachment
Please try to help
Ty a lot
benqoced86
Post by benqoced86 » 11 Apr 2021, 14:13
Added the firmware version in my previous post.
(or check my profile signature) ;)
rafraf
Post by rafraf » 11 Apr 2021, 17:33
Ok maybe firmware problem cuz i have v009, can someone tell me how to return to the 002 ? S
rafraf
Post by rafraf » 12 Apr 2021, 07:03
Can someone who has oc his xl2411p give his firmware version please ?
CtrL
Post by CtrL » 17 Apr 2021, 04:11
Hi. I got the xl2411 screen and i get 165hz (probably can get more but there is where i started). In windows it works but when i open games it will not work and gives black screens and switches modes ect. I have followed the thread so i dont know what im missing here.
FastDuck
Post by FastDuck » 17 Apr 2021, 07:31
xl2420t v1 @120hz report:
S-switch metod, settings for 144hz
And settings for 200hz 1280x1024
Anything lower than 330mhz is fine.
With 200hz screen has bad color vibrance, colors looks washed out
rafraf
Post by rafraf » 17 Apr 2021, 21:12
In my xl2411p anything lower than 330mhz get me no signal ( no out of range only no signal..)
FastDuck
Post by FastDuck » 18 Apr 2021, 12:29
rafraf wrote:
17 Apr 2021, 21:12
I got no signal only when total pixels amount is low. Just use standart settings, try to increase frequency with 10hz step, you should see out of range message, use quide from 1st post for skip oor, increase monitor freq to artifacts and only than reduce total pixels amount with same 10 steps for stability
rafraf
Post by rafraf » 21 Apr 2021, 14:49
I will wait for someone have xl2411p with firmware v9 to make a solution for this monitor.. ty guys
