So Close To OverClocking Ultrawide Monitor
Posted: 19 May 2020, 21:04
OK, so i recently purchased this ACER 34 inch 3440x1440 ips 75 hz monitor from costco.
Its a great value too! image quality is fantastic and has freesync built in! and HDR which works great
I knew about display overclocking and after researching i truly believe this is simply a budget acer predator monitor but simply underclocked to sell for in the budget market. Why? Well going into NVIDIA custom Res Mode and inputting 100hz works! it accepts 100hz and runs it BUT something is off with the bandwidth causing frame skipping which then makes it almost pointless, Im not sure how to lower the bandwidth but i am using Display port only. if i can eliminate the frame skip then this means i could have a great budget monitor at 100hz!!!
can someone point me in the right direction? The very fact he monitor accepts 100hz means it has potential!!
id really appreciate any pointers or help !! thank you
