Overclocking MSI Optix MPG341CQR to 215 Hz [SUCCESS]
LOV
Post by LOV » 25 Jun 2020, 13:45
Hi guys,
Im using MSI Optix mpg341cqr (144hz UWide) and i overclocked to 200hz and 215hz works too.
I did on Nvidia panel but i can only play on windowed mode or windowed fullscreen... If im using fullscreen it automatically change to 144hz.
How can i fix that ?
Thanks.
Post by Chief Blur Buster » 25 Jun 2020, 15:00
LOV wrote:
25 Jun 2020, 13:45
Hi guys,
Thanks.
Wow, nice MSI overclock of 144 Hz to 215 Hz.
To fix that, there are two approaches:
(A) Delete 144 Hz in ToastyX CRU
--or--
(B) Create a different resolution that only has one refresh rate.
My technique is to delete about 1 or 2 pixels from visible resolution, and add 1 or 2 to Vertical Front Porch. I use this trick to force certain games to run at certain unique refresh rates, by forcing some custom resolutions to have only one refresh rate available. I've been using a 1920x1079 trick in some of my games to force a specific refresh rate into a game that stubbornly selects a different refresh rate. By switching resolutions via game settings, I enforce a refresh rate.
After your next reply, I will split your MSI Optix overclocking question to a new thread.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
LOV
Post by LOV » 27 Jun 2020, 13:44
Chief Blur Buster wrote:
25 Jun 2020, 15:00
LOV wrote:
25 Jun 2020, 13:45
Hi guys,
Thanks.
--or--
Hey, thanks for answering,
I can't go over 119hz in my native resolution with CRU, is that normal ?
Like i said, i can go 3440x1440@200hz, and lower resolutions @215hz with custom on Nvidia Panel
200hz (native resolution) on Nvidia Panel :
200hz (native resolution) on CRU :
119hz MAX on CRU :
And with 1920x1080 i can go with 215hz added on CRU and restarted computer, but the frequency doesn't appear on Nvidia Panel or CS:GO.
I'm a bit new in Monitor OC ^^, and just wanna play 1920x1080@215hz in CS:GO and 3440x1440@200hz in Dota2.
Thanks for helping ;)
Jdorman12
Re: Overclocking MSI Optix MPG341CQR to 215 Hz [SUCCESS]
Post by Jdorman12 » 03 Jul 2020, 11:40
Add a display ID as an extension block on the bottom, and add your resolution there, anything over a certain rate won't show up where you put them
Cellx
Post by Cellx » 05 Oct 2020, 10:11
I have the same monitor and anything over 144hz just isn't smooth, can you please share how you did it??
