Hello everybody, How are you?
I'm having problems after doing this tutorial viewtopic.php?t=5544, I'm new to the group and don't understand much about overclocking!
I'm from Brazil, so sorry for my English, it's bad!
The monitor works normally without installing the drivers, installed the drivers, it stops providing images, and is not even appearing on the Nvidia panel!
NOTE: If you uninstall the driver or enter safe mode, the monitor provides an image, and even reaches 144hz!
I wonder if there is any way to return the monitor to its default settings (Hz and resolution)?
Problem whit XL2420Z no have image and driver.
Return to “Display Overclocking”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
