Hello friends, excuse my bad English, I am looking for a 4K monitor but all the ones I find are 60HZ (the cheapest) I only need 75HZ but I cannot find any model with that standard frequency.
Do you know of any 4k model that with a little overclock can reach 75hz? Thank you.
Looking for a monitor, 4K 60hz capable of overclocking to 75hz
Re: Looking for a monitor, 4K 60hz capable of overclocking to 75hz
Very few options here.
For your case, it is probably best to purchase a discounted 4K 120Hz or 4K 144Hz capable panel and then use the refresh rate you want.
The Acer Predator XB273K is 4K 144 Hz and is just about ~$600 which is only about 50% more than a typical budget brand-name 4K panel.
All "FreeSync" monitors ever made, generally supports lower custom fixed-Hz modes too (not just variable refresh rate). FreeSync LCD panels are very refresh-rate-flexible and I've never seen one that couldn't do 75 Hz (for a panel of higher max Hz)
