I tried on a M27Q ips Gigabyte monitor of 170hz with G-sync ON and OFF, a LG ips 21 inch 60hz monitor, diferent LCD TVs, diferent monitors, and all the results are the same
My PC specs are:
CPU: Intel 12700k, 4800 mhz
Liquid cooler for CPU (doesnt go above 60c in heavy load)
GPU: 5080 RTX Gigabyte Aorus (doesnt go above 65c in heavy load)
RAM: 32 GB - 2x 16 GB DDR5 5200 MHz Kingston Fury Beast
Motherboard: ASUS Prime Z690-A
STORAGE: NVME 2TB 750sn Patriot and 500gb 750sn Patriot
PSU: 850W GEN 5 PCI-E ATX 3.0 GOLD GIGABYTE
i tried:
- -Enable the resizable bar from BIOS and check in the Nvidia Control Panel.
-GPU running on Gen3, Gen4 and (currently) Gen5 PCIe (confirmed by GPUz)
-Disabling Vsync and limiting to 60 FPS with RIVA TUNNER
-Changing Monitor overdrive settings
-Changing motion blur settings in game
-Update Bios
-Update Nvidia software and Windows 11.
-Reinstalling Windows 11
-Installing Windows 10
-Disabling Windows Game Mode
-testing changing the GPU to a 4070 Ti, a 1070 Ti, a 2080 Super and a Radeon 6700 XT
-testing changing the RAM and CPU to an Intel 9700k and 16 DDR4
-Changin Motherboard
-Changing NVME
-Changing for diferent PC Screens and TVs
-Enabling and disabling G-Sync in compatible devices
-Changing all setings of Nvidia Panel
-The problems are not particular to one game, every single game from 2000s 2010s and 2020s give me the exact same problem
-Energy lectures are fine
-Temperatures are fine
-Vsync on and off
-Tested on Screens of 60hz native and screens of 170hz native
-Tested Variable Sync
-in BIOS PCI Express Native Power Management → Disable
-in BIOS PCI Express Clock Gating → Disable
-in BIOS ASPM (Active State Power Management) → Disable
-in BIOS Re-Size BAR Support → Enable
-also, disabling resize bar
-in BIOS AI Overclock Tuner → XMP I or XMP II
-in BIOS CPU Base Clock (BCLK) → 100MHz (default)
-updating BIOS and GPU drivers
-cleaninstalling GPU drivers
-Using a UPS Online Synt Wave of 1000va (i only tried it for 3 days, i dont know if it is a problem that takes a lot of time connected to a syntwave connection to get solve)
What could be the problem? I read that it might be judder, but it happens on every screen I try (TV, monitor, etc.).
Is there another “definitive” clean install method for Windows? Or a foolproof version of Windows?
Please, I’m going crazy trying to figure this out.
P.S. I can’t upload gameplay footage due to file size, but if you want to check out my gameplay, I’ve uploaded all the direct captures on my YOUTUBE CHANNEL @Peppy-fr5qh names is Peppy (you will need to compare to other diferents gameplays on youtube to notice the diference and see the level of Judder im talking about)
If you know of any other methods to upload video links to this forum, please let me know.
