Yes, if you reduce red, the image gets "colder."
Anyway, the way I play SDR games is in HDR mode and use Special K to map SDR to HDR with correct gamma.
This panel is natively TB400. It doesn't need a special mode for it.
I don't think anything changed there. 2.2 is still too dark at 180Hz and 240Hz. At 60Hz definitely use 2.2. At 120Hz... it's a split. There's no 2.1 settingPointsintostrength wrote: ↑03 Oct 2026, 06:03Is 2.0 gamma still closer to 2.2 @ 240hz after the 108 firmware update?
