Xl2411z - Defective monitor? It seems stuck to perma 16 bits
tamtam404
Post by tamtam404 » 12 Sep 2014, 22:42
I have a weird issue with my new xl2411z. For some reason the monitor appears to be stuck to 16 bits. For example my windows wallpaper is supposed to be a blue gradient, but I can see the "color circles" where the different blues start and end. If you want to understand what I'm talking about, set your monitor to 16 bits.
By the way, if I manually set the monitor to 16 bits the problem is a lot worse, which means I can see this low bit depth problem even when running at what should be 32 bits. This happen on every pictures, mostly with the blue color (and dark colors in general).
Did I get a defective monitor? My 6 years old LG lcd didn't have this issue.
Falkentyne
Re: Xl2411z - Defective monitor? It seems stuck to perma 16
Post by Falkentyne » 12 Sep 2014, 23:32
ALWAYS try a different cable first. Many problems like that are caused by defective cables.
If it happens on another cable, RMA it.
Q83Ia7ta
Post by Q83Ia7ta » 13 Sep 2014, 03:58
Try other connect to other source other PC or notebook.
