so how he could test more than 15 pcs with everything new in >>different countries<< and be so unlucky to get the exactly same issue at the same level? I also confirmed my interference comes from my body, tried more than 20 pcs and 1 one them was actually way better, but not even close to fix too. it was at my friends house, so this is possible to happen even with the problem being our bodyPatrykelele wrote: β17 Oct 2023, 16:40I would say you might be the problem, but not at all let me expian. I was on gaming event called PGA. Once every year companies can buy space to show their gear and many of them have place to play if you want. I tested pc it was laggy as hell same if i would play from home same lags. Then i went and test next pc in other building damn it was the best gaming experience ever. I don't know why but it might be something about pc gear and monitor.Palacko wrote: β08 Oct 2023, 07:00Hi Guys,
many of you guys will know me from my videos:
https://youtube.com/shorts/PEQYnqav-a4? ... bWsQMzkbkR
As i told before, i am struggeling since 2020 with this problem and the problem followed me whereever i go.
10 different Countries, 15 new Pcs with everything new.
Now i am in Dubai, i play with Account from Gaming Club - 1 Ping to Dubai Servers.
First Hour it was very good i could hit good and then the Problem is starting again, slow movement, slow bullets, prefiring..
I found out that my Body is causing all of this, also people in my House could play good after i move from chair. First its also bad for them, because my inpact to pc/mouse seems huge, and it takes 30-60mins till pc is working fine again.
I never thought that this could be real, but also others reporting about the same.
So it will be unfixable for me, my body has something which is not fitting with gaming anymore. I was ESL #1 in 2007-2010 so i know a lot about Gaming and was like Pro in this time.
I finally found the Reason for my Problem
internetexplorer4
Re: I finally found the Reason for my Problem
[email protected]
Can you remember the specs of the PC and which monitor it was?Patrykelele wrote: β17 Oct 2023, 16:40Then i went and test next pc in other building damn it was the best gaming experience ever. I don't know why but it might be something about pc gear and monitor.
[email protected]
nyxo100
I just cant believe this... why my gaming session is so clean at 3m? every day is the same...
Kipperii
assombrosso
I believe in this
cursed-gamer
internetexplorer4
I also had this for couple years, and also confirmed my interference comes from the body (have tested with people who don't have this problem at the same pc and the problem is there for me but for they its perfect). what I found out is that for me and for some other people, laptops are better (less affected by this problem) and internet/gaming cafes are worse, even with pcs having way better specs than the laptops. laptops in general have way less power consumption than pcs, even if its a gaming laptop compared to a cheap pc, it has way less watts, so it has way less electricity inside it, maybe that's why laptops are better and maybe it has something related to getting better at 3am
Everythingblows
How the hell did you confirm that itβs your body? What did the people around you say when you played on their setup, or they played on yours?
internetexplorer4
my interference makes the keyboard delay so huge that's pretty visible in the game I play (osu) so it makes a completely abnormal behavior in the game because of that, so abnormal that even if people try to reproduce it, they can't. so I tested playing the game with 2 average players in a gaming cafe on the same pc (I play the game for almost 10 years) and they didn't have any issues playing, it was normal for them, and for me I kept getting those extremely terrible scores because of this issue on the mouse and keyboard, but keyboard is more visible. so you can say that maybe I was playing that way because I was already used to play with lag but no, each time the interference was lower for me, my scores instantly improved and I didn't need to get used to anything. the thing is that, the type of scores I get in the game, are like impossible for someone to do even if they play bad on purpose, or even if they are really laggy, if someone who never played the game, play for like 3 months, they would get way better than me without any problem. I have this problem in every game tho, online games feels like I'm playing with 200ms and I have to use 200dpi on desktop because mouse is so floaty. but like you already know, you can't tell someone have this problem just by looking the gameplay, it may look that person is just bad. but in my case with osu is different, like I said, this problem gets really visible because in this game you need to click really fast compared to other games and also aim really fast compared to other games, and you can also see the scores on each map, so everyone who play the game can see that the kind of scores I get are completely abnormal and someone who just play bad or laggy doesn't get those kind of scoresEverythingblows wrote: β23 Dec 2023, 14:59How the hell did you confirm that itβs your body? What did the people around you say when you played on their setup, or they played on yours?
this is what my scores looks like, I get these kind of scores on every map, this is just one example
https://prnt.sc/9eIHjqdZ6uDB
you can see I got 15 misses and 395 of that green in the left, that we call "100" and those 100s means I either clicked too early or too late, but didn't miss the note. in my case it was because I was clicking too late because of the delay, that 58% is the accuracy that it basically tells how precise you were on clicking the notes in the right time, and a normal accuracy for that miss count would be like 95-93% maybe 90% depending of the map, but 58% just doesn't exists in the game, someone would get 58% only if they missed almost every note like missing above 80-100 notes
and this is what a normal score looks like
https://prnt.sc/w0Dqj3TUXcap
same map and 13 misses, you can see he got only 37 100s, which is completely normal for the game, I got 395 and like nobody in the entire community can do that, because I'm not missing, I'm clicking every note delayed
so only by looking the scores you can see the interference, but we can also see through gameplay videos, and I have many.
so I was able to confirm that it is my body because of that
