Serious problem with custom resolution vt trick
MangstaH
i have enabled OS on, I have tried differend setups, even cru and patching nvidia toasty thing. SAd thing is it worked before i resetet my Benq2027z settings to default, after that i havent got my 1350 setup working again. Any helps please?
Re: Serious problem with custom resolution vt trick
Can you tell me if you used the ToastyX method or the NVIDIA Control Panel method?MangstaH wrote:i have enabled OS on, I have tried differend setups, even cru and patching nvidia toasty thing. SAd thing is it worked before i resetet my Benq2027z settings to default, after that i havent got my 1350 setup working again. Any helps please?
It may have stopped working when you upgraded the graphics drivers.
Dotclock might be beyond graphics driver range, so to fix this, try:
- Using ToastyX Pixel Clock Patcher from http://www.monitortests.com
- Or try using a Horizontal Total of 2040, when you do Vertical Total 1350
