useplatformtick and/or disabledynamictick on mouse input lag
Re: useplatformtick and/or disabledynamictick on mouse input lag
Post by Slender » 17 Feb 2024, 12:05
Lev1n wrote:
17 Feb 2024, 10:09
Slender wrote:
16 Feb 2024, 17:03
Lev1n wrote:
16 Feb 2024, 11:28
I dont know whats wrong with my pc. When i enable those tick settings and default timer every game im playing is hella smooth but mouse is not responsive feels like 1kg cant track enemys cant snap and its like playing at 120 ping. When i disable and use .5 or 1 ms timer games and windows is hella responsive but games are not smooth escpecially when shooting. Its been like this for 3 different rig(9900k/10850k and now its 12900ks) only thing didnt changed is my room and ram sticks.
Any suggestions to fix this thing?
for first, what windows version you use?
if win10 it use TSC + TSC tick
if win11 it use TSC + RTC tick
Disabledynamictick work only on w10.
useplatformtick always on at w11 (disabledynamictick not use because that rtc tick).
If you disable HPET from bios, you have worse perfomance with useplatformtick yes (w10, def by w11). What settings you change?
Its 21h2 win10 disabled defender and updates thru ntlite everything is default. Cpu is oc'd to 5.3 1.3 voltage. Rams are xmp on gear1(4k cl16) Didnt touch anything on bios.
Can you send the codes for tweaks you suggest?
if you use w10, you need always open dpc.lat.cheker to decrease kernel timer latency.
(you can check it in latency moon).
for my z790, im use 0.5033 (set 0.5034 in Timertool v3) and always open dpc.lat.cheker.
i get 1ms sleeptime with that trick.
im not use RTC tick on w10 (useplatformtick), but im use disabledynamictick yes, i have better smooth with that, but for some games better deletevalue that for better mouse input.
wilkN
Post by wilkN » 17 Feb 2024, 16:52
Slender wrote:
17 Feb 2024, 12:05
Lev1n wrote:
17 Feb 2024, 10:09
Slender wrote:
16 Feb 2024, 17:03
Lev1n wrote:
16 Feb 2024, 11:28
So you use disabledynamictick yes only or?
And why does dpc lat checker decrease kernel timer latency? o_o
Post by Slender » 17 Feb 2024, 17:01
wilkN wrote:
17 Feb 2024, 16:52
Slender wrote:
17 Feb 2024, 12:05
Lev1n wrote:
17 Feb 2024, 10:09
Slender wrote:
16 Feb 2024, 17:03
you need check it in latency moon (switch settings in to kernel timer latency) before you need open dpc.lat.cheker.
for w11 you not need that, only enable globaltimerrequest from reg
edit: because dpc.lat. use call timer from driver
https://learn.microsoft.com/en-us/windo ... resolution
Lev1n
Post by Lev1n » 18 Feb 2024, 05:56
Slender wrote:
17 Feb 2024, 12:05
Lev1n wrote:
17 Feb 2024, 10:09
Slender wrote:
16 Feb 2024, 17:03
Lev1n wrote:
16 Feb 2024, 11:28
Is there any link for timertool v3? I couldnt find the download link for it.
Post by Slender » 18 Feb 2024, 06:20
Lev1n wrote:
18 Feb 2024, 05:56
Slender wrote:
17 Feb 2024, 12:05
Lev1n wrote:
17 Feb 2024, 10:09
Slender wrote:
16 Feb 2024, 17:03
https://github.com/tebjan/TimerTool
InputLagger
Post by InputLagger » 02 Mar 2024, 16:21
Lev1n wrote:
16 Feb 2024, 11:28
Try to purchase cheap oem green ram sticks from aliexpress or similar Chinas marketplace (amazon :lol: )
jassine
Post by jassine » 27 Aug 2024, 16:12
akylen wrote:
11 Jan 2022, 07:27
For me , the problem is that this is just no fun when i play , i shot more bullets , shot first, shot the guy in the back , i always end up dying , if you're wondering about my level , im global elite and level 10 on faceit, this is just unplayable , my shots didnt register , its like i have to spent 30+ bullets on warzone to remove the armor , and on the killcam of the guy , with the pistol he two shots me .
I dont know what is causing this , but this is not playable at all on all games .
Hello, i had the same issue as you described in many games for 5 years, the solution was to enable HPET in bios and windows (bcdedit /set useplatformclock true).
The only issue is, now i have latency when i check with latencymon:
Average measured interrupt to process latency (µs): 12
Average measured interrupt to DPC latency (µs): 8
Without HPET:
Average measured interrupt to process latency (µs): 3
Average measured interrupt to DPC latency (µs): 0.8
Post by Slender » 29 Aug 2024, 06:28
jassine wrote:
27 Aug 2024, 16:12
akylen wrote:
11 Jan 2022, 07:27
Without HPET:
hpet is bad timer if you set it for main timer.
i think your smooth is way way better, but you 100% have stutters and worse input.
i think you need try ACPI timer (PMT)
for do that you need hard disable hpet in bios and use bcdedit useclock yes.
jassine
Post by jassine » 29 Aug 2024, 11:36
Slender wrote:
29 Aug 2024, 06:28
i disabled hpet in bios and os ( winodws 10 22H2 build 19045.4780), i have:
useplatformclock Yes
useplatformtick Yes
disabledynamictick Yes
the timer still using hpet and the delay is back when gaming.
Post by Slender » 29 Aug 2024, 12:24
jassine wrote:
29 Aug 2024, 11:36
Slender wrote:
29 Aug 2024, 06:28
useplatformtick Yes
you wrong. if hpet is hard disable from bios, and useplatformclock yes it uses ACPI timer with 3.580 clock. You not disable hpet in bios.
and.. dont waste your time with that.
that is affect but it not fix.
