Like my previous Acer XV272UX, this Acer XV272UKF also have a weird bug that if i want to play at 1080p upscale to fullscreen ( for games like Osu! or even Apex Legends on an another build that only have a RTX 3070 ), the screen feel less smooth...
I know now why...these screen have a weird bug on their firmware that lock the refresh rate below 240hz ( like, 144hz, i can have the proof by using G-Sync and when i play at 1440p it's 240hz for the XV272UX and 300hz for XV272UKF but when i downgrade to 1080p upscale fullscreen, i have 144hz on both )
Wth is this bug seriously, on the XV272UX which have an OC 270hz mode, when i activate it and i choose 240hz on the Nvidia Control Panel, it seems to fix the issue but sometimes it doesn't work, like, holy hell how i'm supposed to fixed this issue ?
I've also have this issue with a screen in 2023, the Mobiuz EX270QM.
I also have a bug that is absolutely boring to deal with...but with pratically all recent screen : ALT-TAB is slow and show black screen before show me the other tab.
That's honestly a shame, did you have a proper fix with maybe CRU ? to fixed these issues ?
Weird issues on Acer XV272UKF
Current temporary test : Waiting for the MPG 271QRX QD-OLED | Main monitor : actually nothing | I've had : 1080P : XL2546X / XL2566K / XL2546K / XL2546 / XL2540K / XL2746S / EX2510 / MAG251RX / NXG253R / MAG271CR / VG259QM / VG258QM / XG249CM / XG259CM / VG279QM / S2522HG / XG2431 / XG2405 / XG2702 / AW2518HF / AW2521HF / AW2720HF / 24G2U / Omen X 25 | 1440P : XV272UX / MAG274QRF-QD / 27GP850 / 27GN850 / AW2723DF / Omen X 27 / XG27AQM / XG27AQMR / S2721DGFA / Odyssey G7 / EX270QM / VG27AQML1A / XENEON 27QHD240 / XV272UKF / XV272UX 4K : U28G2XU2 / M32UC
Re: Weird issues on Acer XV272UKF
Please ! someone :c
I really want to keep this monitor, it has good potential, really but a monitor with slow ALT-TAB is really not ideal or pleasant.
I already tried with CRU but nothing seems to work, anyway, it's weird that on this monitor it have 300hz refresh rate but not below, i mean, it only have 60hz > 144hz and then 300hz.
isn't this the same panel as the asus xg27aqmr?
I belive the 270hz panels were better. at least from my testing.
Yes it's the same, an INNOLUX panel.
But what about my issue ?
The XV272UX are clearly not better than the XV272UKF, for some reasons.
Update : I have return this tr*sh monitor.
I know i am late to this, but did you had a second monitor plugged in at the same time? Because that sounds like a known bug, DSC conflicting with nvidia drivers while using multiple monitors causing the 3 seconds ALT-TAB black screen.
