I plan to compare a few settings with each other, for example settings xy with value xy
and see whether they have an influence on the “end-to-end latency”.
I read up a bit and...
I realized that the apparently best method was with a 1000fps camera and
With combination with connection with a built-in LED in the mouse, which must be visible on the recording of the 1000fps camera
example: https://youtu.be/7CKnJ5ujL_Q?t=288
I don't have a 1000fps camera yet and I've read that some people also do it with a "modified mouse" (with built-in LED) and their iPhone
Of course, I am aware that the measurement accuracy is not as precise as, for example, with a 1000fps.
and come back to my actual question
I have 4 recording options on my iPhone 13 mini
"slo-mo" HD 240fps
"slo-mo" HD 120fps
"Video" HD 60fps
"Video" 4k 60fps
A side note I will test with a 360hz monitor "benq zowie xl2566k"
Normally more is better but I wonder whether the iPhone uses a certain type of interpolation of the images when recording at "240fps"
I've been googling for a long time and unfortunately I haven't found anything.
Which of the 4 different recording types would be best suited?
Thanks in advance for reading!
