Emi fix and fix +
MegaMelmek
Re: Emi fix and fix +
Post by MegaMelmek » 26 Feb 2024, 08:09
milkicow wrote:
26 Feb 2024, 07:36
Electrical fields :geek:
If you look carefully on the video he hase the iron connected to same outlet as PC… If i connect the ventiltor to different outlet it will do nothing so its not the iron or ventilator causing the issue is the current close to the PC outlet. So in fact every other machine, may have impact on PC some smaller some one bigger…
milkicow
Post by milkicow » 26 Feb 2024, 08:15
A current creates what? An electrical field
milkicow
Post by milkicow » 26 Feb 2024, 08:17
I don't mean the iron is special or anything
I say that it happens to affect pc this way in case of the video. It might have a different effect in different case
spkii
Post by spkii » 28 Feb 2024, 10:02
Did you try connecting iron same outlet than PC? It really works???
milkicow
Post by milkicow » 05 Mar 2024, 19:11
spkii wrote:
28 Feb 2024, 10:02
I didn't but people give positive feedback for these circuits:
https://media.discordapp.net/attachment ... height=350
https://www.youtube.com/watch?v=k-2yQKKXgO8
https://www.youtube.com/watch?v=bCfGpAq7rYA
Fishie
Post by Fishie » 06 Mar 2024, 05:05
Eh its mixed. Some people are saying its working, some are saying its slightly better. Idk what to make of this.
Programmer, Gamer, Discord: cat.noir
milkicow
Post by milkicow » 06 Mar 2024, 16:18
Fishie wrote:
06 Mar 2024, 05:05
Try for yourself, even if it helps a little it is better than no effect
