Optimal settings with NVIDIA GPU ON A FREESYNC MONITOR
angelolorenzoni
Post by angelolorenzoni » 26 Feb 2024, 20:04
Hello I have an MSI MAG24C on 120Hz paired with an GT1030.
Because and unknow reason I cant disable FreeSync (I think is because I dont have an AMD GPU) and the option still on ON by default.
So, if I want to make the Optimal Settings https://blurbusters.com/gsync/gsync101- ... ttings/14/ What I should do? It applies the same if I activate GSYNC on Nvidia Inspector?
Let me know if more details is needed.
Re: Optimal settings with NVIDIA GPU ON A FREESYNC MONITOR
Post by RealNC » 29 Feb 2024, 12:42
angelolorenzoni wrote:
26 Feb 2024, 20:04
You don't need to disable it. In fact, if you disabled it, g-sync wouldn't work anymore because the display would stop advertising that it's VRR compatible.
