Grounding PC case
- Slender
Grounding PC case
Im see that guide https://www.youtube.com/watch?v=9esauzfuDiQ&t=609s, this guy says that you must strip all the contacts from the case to the motherboard (there are 9 of them), that is, all 9 screws must drain current to the case. Is it correct? I think it would be correct to use 8 non-conducting racks and only one rack at the bottom of the board that conducts current. But he claims that all 9 bolts must conduct current to the case. I always paid attention to the fact that the case is always supplied with 1 gold stock and all the other regular ones (black)
- IMG202402292020312.jpg (72.54 KiB) Viewed 4275 times
Thatweirdinputlag
Re: Grounding PC case
It's actually interesting that you have only one gold stand-off screw. I just checked mine, and all of them are black! Did you try to use the golden one instead of one of the blacks?
MegaMelmek
waste of time i try both of them it will do not help
you but the gold are cheap you can get them on aliexpres
- Slender
i have 9 of this gold, in all case complect it be only one. No, im just scratch black stand-off and install board with silver screws.Thatweirdinputlag wrote: β29 Feb 2024, 13:33It's actually interesting that you have only one gold stand-off screw. I just checked mine, and all of them are black! Did you try to use the golden one instead of one of the blacks?
Im not see big improve, maybe nothing of worse. but im make like that.
- IMG_20240229_220145_984.jpg (109.69 KiB) Viewed 4212 times
- IMG_20240229_220147_585.jpg (145.67 KiB) Viewed 4212 times
- IMG_20240229_220149_017.jpg (189.67 KiB) Viewed 4212 times
Unreazz
Is this the WinkliYT guy? I don't really trust him. He seems to be someone who believes more in placebos and claims to have fixed something without actually making any real improvements. For instance, he asserted that he fixed Valorant's hit registration with RAM timings.
d-unknown
yes it's the guy who claims that rgb strips helps hitreg , and white cases are better than black ones as it fix desyncUnreazz wrote: β29 Feb 2024, 18:36Is this the WinkliYT guy? I don't really trust him. He seems to be someone who believes more in placebos and claims to have fixed something without actually making any real improvements. For instance, he asserted that he fixed Valorant's hit registration with RAM timings.
