Both are bad if you want my opinion
240 HZ Suggestion
Re: 240 HZ Suggestion
Current temporary test : Waiting for the MPG 271QRX QD-OLED | Main monitor : actually nothing | I've had : 1080P : XL2546X / XL2566K / XL2546K / XL2546 / XL2540K / XL2746S / EX2510 / MAG251RX / NXG253R / MAG271CR / VG259QM / VG258QM / XG249CM / XG259CM / VG279QM / S2522HG / XG2431 / XG2405 / XG2702 / AW2518HF / AW2521HF / AW2720HF / 24G2U / Omen X 25 | 1440P : XV272UX / MAG274QRF-QD / 27GP850 / 27GN850 / AW2723DF / Omen X 27 / XG27AQM / XG27AQMR / S2721DGFA / Odyssey G7 / EX270QM / VG27AQML1A / XENEON 27QHD240 / XV272UKF / XV272UX 4K : U28G2XU2 / M32UC
Then, take a cheap monitor and won't complaint if it's bad or you can pay in several installments.
The only one that has decent performance "on paper" at a lower cost is the XG2431 but it is clearly not perfect and I absolutely didn't find anything interesting about it, whether it's the feeling of input lag, the feeling of fluidity or even the menu controls, color saturation, visibility in the dark, it's bad, I didn't like it.
The XL2546X is not expensive for the performance that some less good monitors offer at over 1000 euros.
Hello Sirius,
what's so special about the 46X ? I have the XL2566K and dont have any coil whine at all (been sitting without headphones or music for hours on end while no one else is at home and there's absolute silence in the apartment) , coming from XL2540 in my opinion the 66K is actually an amazing upgrade... with AMA high the UFO's look so clear that DyAc isnt even that necessary to be honest.. (I dont like it in CS2 much either way)
I don't use CRU and i don't need to use that tbh.Asunavlr wrote: ↑14 Mar 2024, 11:08i see u try actually xl2546X, u found good timing with CRU ? default resolution not really good...
Hello, i just bought a xl2546X and i have question about CRU... i need good timings, i think default timing not really strong
I don't have any issues with the actual "timing".
Next that i tried is the MPG 271QRX QD-OLED.
