Hello all, I'm in the market for a new setup entirely and my new pc will be able to consistently hit 240hz. After blowing my entire budget on the pc itself, I was stuck between these two options for a 1440p 240hz monitor. I've heard good things about both and I was leaning more towards the M27Q X for its price but I've seen people complaing about the panel and QC. The LG is also nice but at a higher premium but would the price difference (~$130) be worth the upgrade? I've checked RTNGS' reviews on both and I'm simply torn. I mainly play FPS games like CS and R6 that require low latency and low motion blur.
If all else fails, are there better options around the $400-500 range? Thanks.
Gigabyte M27Q X Or LG 27GR83Q-B?
Re: Gigabyte M27Q X Or LG 27GR83Q-B?
Bump. If you get a response to this I want to know too. I’m looking for a non flickering 240hz monitor to work with gsync.
both displays have review on rtings, and their response time @ max refresh is basically the same, so i dont think +$130 would be worth if thats the primary concern.
posting your region might help others help you find a monitor because pricing and availability is not the same everywhere
M27Q (rev 2.0
past: random Kogan VA monitor (same panel as Viotek GN24C),
Philips 276E8VJSB
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
Philips 276E8VJSB
