This Is How I Fixed*(asterik!) My Own Input Lag [Update #3]
ACDynamite
Re: This Is How I Fixed My Input Lag [Update]
Post by ACDynamite » 17 May 2024, 00:27
I just wanted to say thank you very much. I've been struggling with really bad mouse lag/floaty feeling and this is the first "fix" that has made a noticeable difference.
CS2 feels MUCH better after running extensive tests to rule out placebo.
Everything from bios tweaks to reg edits, EMI testing and more - it has all been tried and failed.
THANKS ONCE AGAIN.
Here's my specs if anyone is interested:
- CPU: Intel Core i7-14700K
- MOBO: ASUS ROG STRIX Z790-H GAMING WIFI
- RAM: GSkill DDR5 32Gb (16 X 2) (@6000 XMP Enabled)
- GPU: GIGABYTE GeForce RTX 4070 AERO OC 12G
- PSU: Super Flower 850Watt
- STORAGE: NVMe M.2 1Tb
- Windows 11 Pro (23H2 - up to date)
Syykfk
Post by Syykfk » 17 May 2024, 21:57
ACDynamite wrote:
17 May 2024, 00:27
THANKS ONCE AGAIN.
Which action did you use to fix it?
F1zus
Post by F1zus » 18 May 2024, 18:50
ACDynamite wrote:
17 May 2024, 00:27
THANKS ONCE AGAIN.
According to your version, wmi crashes, but where are these errors displayed and how do they manifest themselves? In the event log?
After resetting wmi, the registry settings will not be reset?
dermodemon
Post by dermodemon » 19 May 2024, 09:02
after cmd command winmgmt /resetrepository i can't run my apps and everything is lagging hard (win11)
Foul Play
Re: This Is How I Fixed My Input Lag [Update #2]
Post by Foul Play » 19 May 2024, 10:26
dermodemon wrote:
19 May 2024, 09:02
I am very sorry as I didn't mean any harm.
widow13
Post by widow13 » 19 May 2024, 10:46
dermodemon wrote:
19 May 2024, 09:02
Always create a restore point before trying random tweaks as this could happen.
Hyote
Post by Hyote » 19 May 2024, 11:01
This is not a solution to anything and it's not recommended to clear it all the time.
giggio10
Post by giggio10 » 19 May 2024, 11:28
Hyote wrote:
19 May 2024, 11:01
Just because it didn't do anything for you, doesn't mean it won't for anyone. Tried it 3 days ago and it's still working
dermodemon
Post by dermodemon » 19 May 2024, 12:37
Foul Play wrote:
19 May 2024, 10:26
dermodemon wrote:
19 May 2024, 09:02
No, it's okay my man, restarted my pc and it is working as always now, don't worry about it
Ragerlis
Post by Ragerlis » 19 May 2024, 13:30
You want to stop the WMI before resetting it to avoid crashes and errors spam.
net stop winmgmt
