jassine
Post by jassine » 26 May 2024, 09:09
can someone with RSS enabled share the result of: Get-NetAdapterRss
BlurWickd
Post by BlurWickd » 26 May 2024, 12:23
jassine wrote: ↑
26 May 2024, 09:09
After entering your script - now I see number of rss queues, receive side scaling and rss load balancing profile in the advanced settings in device manager. Its set to 4 and rss load balancing profile set to numastatic is this right?
I'm not sure if its working because the indirection table is empty though.
Screenshot 2024-05-26 182305.png (20.23 KiB) Viewed 14076 times
Unreazz
Post by Unreazz » 26 May 2024, 13:34
as you requested
JimCarry
Post by JimCarry » 26 May 2024, 14:35
Unreazz wrote: ↑
25 May 2024, 23:44
JimCarry wrote: ↑
25 May 2024, 20:07
Unreazz wrote: ↑
25 May 2024, 19:12
JimCarry wrote: ↑
25 May 2024, 17:25
i dont think you are right,if rss works its day and night difference.
What do you mean ? you can just simply activate it via powershell command. there is no reg edit needed
do you even read what he type ? he dont even have it ?
i was not talking about him, i mean, what do you mean with "if rss works its day and night difference" why is it in your case then not activated ? or does it not working out for you ?
i give you example there is tweak in the internet.
https://www.youtube.com/watch?v=OzEOUUmtzRY
at 5:28 you see you can change the msi limit for example mine max is 2048
i found my max with go GoInterruptPolicy.exe and after setting it to 2048 you see in msinfo32
my realtek going from one irq to 4 maybe because my realtek can make only 4 ? but after this tweak rss enabled makes huge diffrence i dont know how but in my case does.
JimCarry
Post by JimCarry » 26 May 2024, 14:36
jassine wrote: ↑
26 May 2024, 09:09
i will today later.
jassine
Post by jassine » 26 May 2024, 15:40
Unreazz wrote: ↑
26 May 2024, 13:34
as you requested
what driver are u using ? and Could you please tell us your setup (MB, cpu) ?
because my results are as same as BlurWickd, IndirectionTable and RssProcessorArray are empty and we have same network card; im confused.
BlurWickd wrote: ↑
26 May 2024, 12:23
BlurWickd
Post by BlurWickd » 26 May 2024, 16:57
jassine wrote: ↑
26 May 2024, 15:40
Unreazz wrote: ↑
26 May 2024, 13:34
as you requested
BlurWickd wrote: ↑
26 May 2024, 12:23
I used the latest on the realtek website, the one that doesn't support powersaving. The odd thing is that I reinstalled the one from my motherboard site which seems to be the exact same version yet the indirection table is full now and it has rss already? wtf?
7950x3d, MSI x670e TOMAHAWK Wifi
jassine
Post by jassine » 26 May 2024, 17:58
BlurWickd wrote: ↑
26 May 2024, 16:57
I just did what you did, i installed realtek driver from their website, then installed my MB's driver (Gigabyte B550 AORUS ELITE V2 rev 1.4) and boom, i have everything, thats weird.
Capture d'écran 2024-05-26 235446.png (44.35 KiB) Viewed 13905 times
JimCarry
Post by JimCarry » 26 May 2024, 18:23
BlurWickd wrote: ↑
26 May 2024, 12:23
jassine wrote: ↑
26 May 2024, 09:09
Disabletaskoffload to 0 and indirection table should be working
JimCarry
Post by JimCarry » 26 May 2024, 18:25
BlurWickd wrote: ↑
26 May 2024, 16:57
jassine wrote: ↑
26 May 2024, 15:40
Unreazz wrote: ↑
26 May 2024, 13:34
as you requested
BlurWickd wrote: ↑
26 May 2024, 12:23
Disabletaskoffload is 0 if indirection table has number in it,it means on boar processor on realtek is on and working.
