jassine
can someone with RSS enabled share the result of: Get-NetAdapterRss
BlurWickd
After entering your script - now I see number of rss queues, receive side scaling and rss load balancing profile in the advanced settings in device manager. Its set to 4 and rss load balancing profile set to numastatic is this right?
I'm not sure if its working because the indirection table is empty though.
- Screenshot 2024-05-26 182305.png (20.23 KiB) Viewed 14093 times
Unreazz
as you requested
JimCarry
i give you example there is tweak in the internet.Unreazz wrote: ↑25 May 2024, 23:44i was not talking about him, i mean, what do you mean with "if rss works its day and night difference" why is it in your case then not activated ? or does it not working out for you ?
https://www.youtube.com/watch?v=OzEOUUmtzRY
at 5:28 you see you can change the msi limit for example mine max is 2048
i found my max with go GoInterruptPolicy.exe and after setting it to 2048 you see in msinfo32
my realtek going from one irq to 4 maybe because my realtek can make only 4 ? but after this tweak rss enabled makes huge diffrence i dont know how but in my case does.
JimCarry
jassine
what driver are u using ? and Could you please tell us your setup (MB, cpu) ?
because my results are as same as BlurWickd, IndirectionTable and RssProcessorArray are empty and we have same network card; im confused.
BlurWickd wrote: ↑26 May 2024, 12:23After entering your script - now I see number of rss queues, receive side scaling and rss load balancing profile in the advanced settings in device manager. Its set to 4 and rss load balancing profile set to numastatic is this right?
BlurWickd
I used the latest on the realtek website, the one that doesn't support powersaving. The odd thing is that I reinstalled the one from my motherboard site which seems to be the exact same version yet the indirection table is full now and it has rss already? wtf?jassine wrote: ↑26 May 2024, 15:40what driver are u using ? and Could you please tell us your setup (MB, cpu) ?
7950x3d, MSI x670e TOMAHAWK Wifi
jassine
I just did what you did, i installed realtek driver from their website, then installed my MB's driver (Gigabyte B550 AORUS ELITE V2 rev 1.4) and boom, i have everything, thats weird.BlurWickd wrote: ↑26 May 2024, 16:57I used the latest on the realtek website, the one that doesn't support powersaving. The odd thing is that I reinstalled the one from my motherboard site which seems to be the exact same version yet the indirection table is full now and it has rss already? wtf?
- Capture d'écran 2024-05-26 235446.png (44.35 KiB) Viewed 13922 times
JimCarry
Disabletaskoffload to 0 and indirection table should be workingBlurWickd wrote: ↑26 May 2024, 12:23After entering your script - now I see number of rss queues, receive side scaling and rss load balancing profile in the advanced settings in device manager. Its set to 4 and rss load balancing profile set to numastatic is this right?
JimCarry
Disabletaskoffload is 0 if indirection table has number in it,it means on boar processor on realtek is on and working.BlurWickd wrote: ↑26 May 2024, 16:57I used the latest on the realtek website, the one that doesn't support powersaving. The odd thing is that I reinstalled the one from my motherboard site which seems to be the exact same version yet the indirection table is full now and it has rss already? wtf?jassine wrote: ↑26 May 2024, 15:40what driver are u using ? and Could you please tell us your setup (MB, cpu) ?
