Windows 10 Optimisation Guide
Hyote
Re: Windows 10 Optimisation Guide
Post by Hyote » 16 May 2024, 14:26
Coldplayer wrote:
16 May 2024, 03:25
delete SmoothMouseXCurve and SmoothMouseYCurve in Computer\HKEY_CURRENT_USER\Control Panel\Mouse, MouseSpeed 0 ; MouseHoverTime 0 ; new String value: MouseAccel ; MouseAccel_Max ; MouseAccel_Scale all of them to 0
Can you screenshot what this should look like?
Instead of deleting SmoothMouseX and Y I now recommend changing their values to 0. Here is a pic of my regedit.
joolae
Post by joolae » 19 May 2024, 00:50
Here's mine for mouse: accel @0 , no accel max/scale, hover time at 10, and I highly suggest to try mouse speed at "-".
dizelcs
Post by dizelcs » 03 Jun 2024, 06:43
Slender wrote:
15 May 2024, 20:03
install LTSC w10 21h2 with Revi-Config via ventoy usb installation.
Is ventoy superior to rufus, besides the multiple iso's on 1 usb?
Post by Slender » 04 Jun 2024, 07:02
dizelcs wrote:
03 Jun 2024, 06:43
Slender wrote:
15 May 2024, 20:03
when you do what I wrote, you will understand
kenj12345
Post by kenj12345 » 04 Jun 2024, 07:27
Slender wrote:
04 Jun 2024, 07:02
dizelcs wrote:
03 Jun 2024, 06:43
Slender wrote:
15 May 2024, 20:03
excuse me, but can I go into more detail, is revi-config revios?21 h2 ltsc does faceit work?
dizelcs
Post by dizelcs » 04 Jun 2024, 17:14
Slender wrote:
04 Jun 2024, 07:02
dizelcs wrote:
03 Jun 2024, 06:43
Slender wrote:
15 May 2024, 20:03
I'm also using Revi config, but winver 22h2 and installed with rufus.
I will try ventoy method for weekend. Thanks.
Post by Slender » 04 Jun 2024, 17:26
kenj12345 wrote:
04 Jun 2024, 07:27
Slender wrote:
04 Jun 2024, 07:02
dizelcs wrote:
03 Jun 2024, 06:43
Slender wrote:
15 May 2024, 20:03
i dont know i dont use tpm
