I know this is how Intel Turbo Boost works, it's by design, so no idea how you have it working since your cpu isn't even unlocked.sherifmagdy32 wrote: ↑07 Jun 2024, 12:30I am replying to you from my old pc with b365 motherboard and i9400f cpu with c states disabled and turboboost working just fine like i said before
Should i leave Global C-States Disabled by default?
MatrixQW
Re: Should i leave Global C-States Disabled by default?
sherifmagdy32
MatrixQW
Select power plan High Performance or Ultimate (since I think this is what you are using).JimCarry wrote: ↑07 Jun 2024, 10:39So guys i did not get anything,so i have i5 6600 in the intel site it says "Intel® Core™ i5-6600 Processor 6M Cache, up to 3.90 GHz" i have it for 2 years i have never seen go above 3.3GHz,so guys how can i test and see if i must disable all c-state like show on the picture,and then just enable "Intel Speed Step Technology".Because right now all the c-states are off and "Intel Speed Step Technology" is off.And it task manager says 3.31ghz.
See what frequency it shows in each of your cores in HWInfo64.
Then go to BIOS and enable SpeedStep and try again.
If it still doesn't go beyond 3.3, enable C-States in BIOS and Windows in the power plan (demote = 40% and promote = 60%).
My CPU is 3.5 base and 3.9 turbo. All my cores work at turbo speed while in High Performance power plan.
- cpu.png (69.43 KiB) Viewed 13762 times
JimCarry
There is no diffrence between High and Ultimate power plans,i use ultimate,i did enable "Intel(R) SpeedStep(tm)",set demote and promote like you said,still no difrrence i will provide screenshot,also wich of the c-state i should enable?MatrixQW wrote: ↑07 Jun 2024, 13:54Select power plan High Performance or Ultimate (since I think this is what you are using).JimCarry wrote: ↑07 Jun 2024, 10:39So guys i did not get anything,so i have i5 6600 in the intel site it says "Intel® Core™ i5-6600 Processor 6M Cache, up to 3.90 GHz" i have it for 2 years i have never seen go above 3.3GHz,so guys how can i test and see if i must disable all c-state like show on the picture,and then just enable "Intel Speed Step Technology".Because right now all the c-states are off and "Intel Speed Step Technology" is off.And it task manager says 3.31ghz.
- promote.GIF (46.61 KiB) Viewed 13735 times
JimCarry
sherifmagdy32 wrote: ↑07 Jun 2024, 13:53this is not the default high performance power plan, the power plan you using probably have something wrongJimCarry wrote: ↑07 Jun 2024, 13:27i am still no diffrence.sherifmagdy32 wrote: ↑07 Jun 2024, 12:493.9GHz is only when 1 core is being utilized but for all of them it should be 3.6Ghz make sure you on high performance power planJimCarry wrote: ↑07 Jun 2024, 10:39
https://youtu.be/PEYDbrjurI0?t=648
also i am now with default so its nothing to do with power plan.
MatrixQW
Enable all states except C1E, like in here:
And see if they are working in HWInfo64 in C-State Residency. Cores should be in C7 most of the time.
JimCarry
what do u mean by "Enable all states except C1E, like in here"?
also i upload the screenshot you wanted from hwinfo
- hw.GIF (34.72 KiB) Viewed 13715 times
MatrixQW
Press the up arrow to the right of "MatrixQW wrote:" with the text "see screenshot" under, of my own quote.
Your cores are at 3.6 so turbo boost works, it just isn't reaching 3.9 full speed.
JimCarry
are you talking about this ?
- wqeqweqweqweq.GIF (333.82 KiB) Viewed 13698 times
JimCarry
