Should i leave Global C-States Disabled by default?
JimCarry
Re: Should i leave Global C-States Disabled by default?
Post by JimCarry » 07 Jun 2024, 15:09
MatrixQW wrote: ↑
07 Jun 2024, 14:53
JimCarry wrote: ↑
07 Jun 2024, 14:37
what do u mean by "Enable all states except C1E, like in here"?
also i upload the screenshot you wanted from hwinfo
Press the up arrow to the right of "MatrixQW wrote:" with the text "see screenshot" under, of my own quote.
Your cores are at 3.6 so turbo boost works, it just isn't reaching 3.9 full speed.
So i enabled "Intel(R) SpeedStep(tm)" "CPU C-states" ,using default power plan i did not touch anything demote promote is exactcly as you said.nothing changed.i provide screenshot of the default power plan and the hwinfo you wanted after enabling and doing what you said.
default p[ower plan.GIF (27.42 KiB) Viewed 7725 times
MatrixQW
Post by MatrixQW » 07 Jun 2024, 15:37
If you didn't touch the High Performance demote/promote and 'Processor performance time check interval' then all is good.
By the way, humor me, disable C-States in BIOS and see if cores still stay at 3.6 in HWInfo64.
Run something heavy to put load on the cores to see if they go above 3.6.
If they don't, most likely they are locked by turbo limits.
With the app ThrottleStop you can see turbo limits. Press the FIVR button.
I warn you to touch absolutely NOTHING, use it just to see the default values of your cpu and close the app without pressing 'OK'.
Also, see if you can set in BIOS your CPU Core Ratio.
JimCarry
Post by JimCarry » 07 Jun 2024, 17:16
MatrixQW wrote: ↑
07 Jun 2024, 15:37
my settings are exactly the same like your screenshot i also have bios mb.
JimCarry
Post by JimCarry » 07 Jun 2024, 17:49
MatrixQW wrote: ↑
07 Jun 2024, 15:37
"If you didn't touch the High Performance demote/promote and 'Processor performance time check interval' then all is good."
as i said default nothing but i checked its 60/40 like you want.
"By the way, humor me, disable C-States in BIOS and see if cores still stay at 3.6 in HWInfo64."
i upload picture first is with c-states ebabled second is without of course i restart pc after disable it.
JimCarry
Post by JimCarry » 07 Jun 2024, 18:24
I think i found something speed step off versus on.
speed step off.GIF (44.4 KiB) Viewed 7636 times
Riggedinho
Post by Riggedinho » 07 Jun 2024, 23:19
It's strictly up to your feeling in the game...
in my humble opinion you should leave C-state enabled as it may aggravate your feeling in the game.
So yes, in LatencyMon you'll have considerably reduced system latency, but at what cost? isn't that just a placebo?
Personally, I've come to the point (in relation to the problem I was facing) where I think it's much better to leave the default bios and let things take their course.
The lower the latency on my system, the worse my game feels.
It's no longer 2017 on CS:GO
MatrixQW
Post by MatrixQW » 08 Jun 2024, 00:31
JimCarry wrote: ↑
07 Jun 2024, 18:24
Now you know, you need SpeedStep enabled for Turbo Boost to work. In BIOS, enable SpeedStep and C-States (disable C1E only).
I think your CPU is locked and you can't set turbo ratio limits, try in BIOS anyway, when four cores are being used it will only reach 3.6.
MatrixQW
Post by MatrixQW » 08 Jun 2024, 00:41
Riggedinho wrote: ↑
07 Jun 2024, 23:19
It should be enabled in BIOS and in some cases or by user choice disable it only for High Performance power plan.
Games that read alot from SSD, having C-States enabled could actually cause stuttering or increase frametime.
About a game feeling more responsive with it disabled, that's why I told Benjji1 to test it on the fly while gaming.
If there is a big enough difference it will be noticeable.
JimCarry
Post by JimCarry » 08 Jun 2024, 10:31
MatrixQW wrote: ↑
08 Jun 2024, 00:31
JimCarry wrote: ↑
07 Jun 2024, 18:24
Yes and thanks i disable all of the c-state ralated options in my bios and i show a picture off what i disabled + enable only speedstep + hwinfo after this.And yes i think you are right for my cpu wich is intel NON-k if u disable speedstep you loose perfomance.
JimCarry
Post by JimCarry » 08 Jun 2024, 10:51
MatrixQW wrote: ↑
08 Jun 2024, 00:41
Riggedinho wrote: ↑
07 Jun 2024, 23:19
I will never let it enable i disable all of the c-state related options as i show in the picture above,with or without them i think there is diffrence,but hw info did not show any diffrence as you saw in the screenshot,the only thing that did make diffrence was intel speedstep.So after the test i did i can conclude:
stock high perfomance power plan i did not touch anything + c state all disabled or enabled i test both there is no diffrence in hwinfo
after that i restart and disabled all c state + steepd steep on ,you can see the diffrence in the screen above
after that i apply this hidden power plan tweaks
after that still no diffrence in hwinfo (3.6ghz)
so i add this tweaks to my power plan and the cpu is still 3.6ghz so think i will leave it like that.
pwr optz.GIF (58.26 KiB) Viewed 7434 times
