So i enabled "Intel(R) SpeedStep(tm)" "CPU C-states" ,using default power plan i did not touch anything demote promote is exactcly as you said.nothing changed.i provide screenshot of the default power plan and the hwinfo you wanted after enabling and doing what you said.
Should i leave Global C-States Disabled by default?
JimCarry
Re: Should i leave Global C-States Disabled by default?
- default p[ower plan.GIF (27.42 KiB) Viewed 7548 times
MatrixQW
If you didn't touch the High Performance demote/promote and 'Processor performance time check interval' then all is good.
By the way, humor me, disable C-States in BIOS and see if cores still stay at 3.6 in HWInfo64.
Run something heavy to put load on the cores to see if they go above 3.6.
If they don't, most likely they are locked by turbo limits.
With the app ThrottleStop you can see turbo limits. Press the FIVR button.
I warn you to touch absolutely NOTHING, use it just to see the default values of your cpu and close the app without pressing 'OK'.
Also, see if you can set in BIOS your CPU Core Ratio.
- bios_core_ratio.jpg (233.44 KiB) Viewed 7539 times
- throttlestop_FIVR.png (58.66 KiB) Viewed 7539 times
JimCarry
my settings are exactly the same like your screenshot i also have bios mb.MatrixQW wrote: ↑07 Jun 2024, 15:37If you didn't touch the High Performance demote/promote and 'Processor performance time check interval' then all is good.
- thr.GIF (243.13 KiB) Viewed 7503 times
JimCarry
"If you didn't touch the High Performance demote/promote and 'Processor performance time check interval' then all is good."MatrixQW wrote: ↑07 Jun 2024, 15:37If you didn't touch the High Performance demote/promote and 'Processor performance time check interval' then all is good.
as i said default nothing but i checked its 60/40 like you want.
"By the way, humor me, disable C-States in BIOS and see if cores still stay at 3.6 in HWInfo64."
i upload picture first is with c-states ebabled second is without of course i restart pc after disable it.
- predi.GIF (44.53 KiB) Viewed 7491 times
- sled.GIF (40.26 KiB) Viewed 7491 times
JimCarry
I think i found something speed step off versus on.
- speed step off.GIF (44.4 KiB) Viewed 7459 times
- on.GIF (42.4 KiB) Viewed 7459 times
Riggedinho
It's strictly up to your feeling in the game...
in my humble opinion you should leave C-state enabled as it may aggravate your feeling in the game.
So yes, in LatencyMon you'll have considerably reduced system latency, but at what cost? isn't that just a placebo?
Personally, I've come to the point (in relation to the problem I was facing) where I think it's much better to leave the default bios and let things take their course.
The lower the latency on my system, the worse my game feels.
It's no longer 2017 on CS:GO
MatrixQW
Now you know, you need SpeedStep enabled for Turbo Boost to work. In BIOS, enable SpeedStep and C-States (disable C1E only).
I think your CPU is locked and you can't set turbo ratio limits, try in BIOS anyway, when four cores are being used it will only reach 3.6.
MatrixQW
It should be enabled in BIOS and in some cases or by user choice disable it only for High Performance power plan.Riggedinho wrote: ↑07 Jun 2024, 23:19It's strictly up to your feeling in the game...
Games that read alot from SSD, having C-States enabled could actually cause stuttering or increase frametime.
About a game feeling more responsive with it disabled, that's why I told Benjji1 to test it on the fly while gaming.
If there is a big enough difference it will be noticeable.
JimCarry
Yes and thanks i disable all of the c-state ralated options in my bios and i show a picture off what i disabled + enable only speedstep + hwinfo after this.And yes i think you are right for my cpu wich is intel NON-k if u disable speedstep you loose perfomance.MatrixQW wrote: ↑08 Jun 2024, 00:31Now you know, you need SpeedStep enabled for Turbo Boost to work. In BIOS, enable SpeedStep and C-States (disable C1E only).
- 1.GIF (82.82 KiB) Viewed 7267 times
JimCarry
I will never let it enable i disable all of the c-state related options as i show in the picture above,with or without them i think there is diffrence,but hw info did not show any diffrence as you saw in the screenshot,the only thing that did make diffrence was intel speedstep.So after the test i did i can conclude:MatrixQW wrote: ↑08 Jun 2024, 00:41It should be enabled in BIOS and in some cases or by user choice disable it only for High Performance power plan.Riggedinho wrote: ↑07 Jun 2024, 23:19It's strictly up to your feeling in the game...
stock high perfomance power plan i did not touch anything + c state all disabled or enabled i test both there is no diffrence in hwinfo
after that i restart and disabled all c state + steepd steep on ,you can see the diffrence in the screen above
after that i apply this hidden power plan tweaks
after that still no diffrence in hwinfo (3.6ghz)
so i add this tweaks to my power plan and the cpu is still 3.6ghz so think i will leave it like that.
- pwr optz.GIF (58.26 KiB) Viewed 7257 times
