ASUS ROG Swift 500Hz Announced!
gab848
Re: ASUS ROG Swift 500Hz Announced!
Post by gab848 » 04 Apr 2024, 06:37
daviddave1 wrote:
03 Apr 2024, 11:23
i got the 1728x1080 500hz to work!
disable overclocking. then in nvidia panel u can just make the custom res! someone shared this info on a discord. Pretty happy atm.
I already knew this. If you disable OC, you can make all the custom resolutions you want with 500Hz. But I appreciate you sharing either way.
daviddave1
Post by daviddave1 » 07 Apr 2024, 02:41
I just made this topic in the overclocking section viewtopic.php?t=13280
If someone know how to overclock this monitor from 360hz to 480hz with dcs disabled please share!
| Now: XG27AQNGV
chris75buck
Post by chris75buck » 15 Apr 2024, 14:38
Could anyone send the ICC profile again?
hugebychoice
Post by hugebychoice » 17 May 2024, 07:07
Does anyone else have pulsating vertical lines when the monitor (PG248QP) is set to 60Hz? Also, extreme pixel inversion artifacts at 500+ Hz? It seems to be less clear than my previous XL2566K and my eyes hurt when looking at it for a while...
phzera
Post by phzera » 04 Jul 2024, 12:38
Chief Blur Buster wrote:
30 Nov 2023, 01:33
meow wrote:
29 Nov 2023, 20:35
I tried leaving the monitor running for 72 hours to relieve some of the pressure spots mine had and ended up with a corrupt OSD. Unplugging and replugging fixed it but now I'm afraid to even use it.
You shouldn't be.
I've seen it happen before, monitors are literally computers built into them now. Driving a 1080p+ panel at 240Hz+ requires more computer power than the Cray-1 supercomputer of 1980s!
Something probably "crashed" in the monitor firmware, like a 4am power brownout/brief "flash" blackout, or like a stray cosmic ray, or some temporary heat-induced problem (if room was very hot too, like a heater behind the monitor), or other thing.
Give your monitor enough ventilation and you should be OK!
If it happens again, at least you know a new defect may have popped up.
But it could have just been a simple "computer crash" inside your monitor, triggered by something like heat or your power company, etc.
Hello friend, firstly sorry for my English, it's not my native language.
Is this also related to a bug that happened to me and a few other people on the forums?
When I received my monitor, when activating ULMB2 my screen was white, and only returned to normal, after restarting the monitor and turning off ULMB2 quickly, if I activated it, in a few seconds my screen would be white again, I have a video recorded about this in attachment.
After a few days of use, without using the ULMB2, I decided to activate the ULBM2 again, and to my surprise the problem never happened again since then.
I just didn't return the monitor, because I imported it from the United States to my country, and it would be very bureaucratic to make a return,
ASUS ULMB 2 BUG_2.mp4
(5.98 MiB) Downloaded 595 times
phzera
Post by phzera » 05 Jul 2024, 12:37
gab848 wrote:
04 Apr 2024, 06:37
daviddave1 wrote:
03 Apr 2024, 11:23
It doesn't work for me, it only works at 360 hz, is there any update on that? which driver are you using?
daviddave1
Post by daviddave1 » 05 Jul 2024, 13:06
phzera wrote:
05 Jul 2024, 12:37
gab848 wrote:
04 Apr 2024, 06:37
daviddave1 wrote:
03 Apr 2024, 11:23
546.17
Make sure to turn off Overclocking, Turn on fullscreen Display Scaling in nvdia settings, also Gsync off if it does not work
| Now: XG27AQNGV
phzera
Post by phzera » 05 Jul 2024, 15:12
daviddave1 wrote:
05 Jul 2024, 13:06
phzera wrote:
05 Jul 2024, 12:37
gab848 wrote:
04 Apr 2024, 06:37
daviddave1 wrote:
03 Apr 2024, 11:23
546.17
With this driver it work, with the latest versions it is not possible. Thanks
daviddave1
Post by daviddave1 » 05 Jul 2024, 16:23
phzera wrote:
05 Jul 2024, 15:12
daviddave1 wrote:
05 Jul 2024, 13:06
phzera wrote:
05 Jul 2024, 12:37
gab848 wrote:
04 Apr 2024, 06:37
546.17
yw I'm glad it works.
| Now: XG27AQNGV
