[Bad LOD in Games | Juddering PC] Management Engine(Locked/Damaged) - Enhanced i/o issues [Closed/Not Relevant]
- Slender
Re: [Bad LOD in Games | Juddering PC] Management Engine(Locked/Damaged) - Enhanced i/o issues
intel graphic
- IMG_20240620_153351_631.jpg (288.69 KiB) Viewed 15432 times
texre
I honestly dont know. I did have problems with my electricity. I just fixed my burning electrical panel
And my game ran so good for days I had a 8kd then it went back to being bad. So I honestly have no clue. People move and still have the problem so really this makes more logical sense. I remember before I moved from my house where everything ran good then I got a new pc then moved like 1 week later. But I can recall that when I got my new pc at good location I started doing worse. So I def think it can be lod and not electricity
Kipperii
Has the air purifier solution failed? Brotexre wrote: ↑20 Jun 2024, 13:26I honestly dont know. I did have problems with my electricity. I just fixed my burning electrical panel
texre
it def makes it better but this issue had came back after like 6 months, its super dusty where i live but its definitely not a solution andKipperii wrote: ↑02 Jul 2024, 22:24Has the air purifier solution failed? Brotexre wrote: ↑20 Jun 2024, 13:26I honestly dont know. I did have problems with my electricity. I just fixed my burning electrical panel
i never recommended anybody to buy one either so pls dont buy one lol
- Slender
- Z3CrosS
I think that i don't think
- Slender
- Slender
author of these pic say this is same resolution.
after reinstall windows, image is clear (day), but today at night it same broken like always.
"So, I flashed my bios with the lastest version and install each drivers of my motherboard.
Everyting was looking good so far but the problem started again tonight on RE VIII
I took pictures the day where it worked great and tonight and we can see the difference.
The second picture is way sharper than the 2sd
I didn't change anything on my settings or in my system between the two times I played.
All my other games looks fine so far but RE VIII has the same issue that I had before.
Have you any idea?"
Have you any idea?"
- 1621203482-re8-2.jpg (151.48 KiB) Viewed 13489 times
- 1621203481-re8-1.jpg (136.19 KiB) Viewed 13489 times
- Z3CrosS
texre
i got all new parts, boxed windows usb , day 4..... yes it feels good. ill keep you guys updated
