Katowice is not a major but it is just as prestigious and Donk plays in 800 DPI
What improved my hitreg/mouse tracking/desync in CS2
Riggedinho
Re: What improved my hitreg/mouse tracking/desync in CS2
there are quite a few professionals who play at 800 DPI.
ok 3 PROs,who plays at 800 dpi but his mouse hz is not 125.Riggedinho wrote: ↑23 Jun 2024, 12:02there are quite a few professionals who play at 800 DPI.
Katowice is not a major but it is just as prestigious and Donk plays in 800 DPI![]()
Riggedinho
initially the speaker was talking about the pros at 800 dpi and not 800 dpi at 125 Hz it is true that no one in 2024 plays with a rate at 125 Hz but if the author of this post feels better with this value it is because There's a problem somewhere.
All this other feedback makes sense with regard to CS 2. In any case with regard to my personal configuration I can relate to it.
And then saying "a guy" for Donk is somewhat irreverent lol already he's not a guy but a kid (jokes aside) he's not a simple "guy" but he's a crack through these stats on Katowice and a legend in the making.
i mean PRO sorry i will edit it.Riggedinho wrote: ↑23 Jun 2024, 12:18initially the speaker was talking about the pros at 800 dpi and not 800 dpi at 125 Hz it is true that no one in 2024 plays with a rate at 125 Hz but if the author of this post feels better with this value it is because There's a problem somewhere.
exactly he has world record for best perfomance,but if you look at the world record performance that he did,you can see his settings mouse dpi mouse hz and monitor hz.Riggedinho wrote: ↑23 Jun 2024, 12:18initially the speaker was talking about the pros at 800 dpi and not 800 dpi at 125 Hz it is true that no one in 2024 plays with a rate at 125 Hz but if the author of this post feels better with this value it is because There's a problem somewhere.
Riggedinho
don't worry I don't need to look at the full specifications of Donk I just wanted to note that it plays at 800 DPI
yep but he is using at least 1000 Hz mouse polling rate,and m0nesy usesss 2000 Hz mouse polling rate source: https://youtu.be/DsaRy_Uqx1k?t=939Riggedinho wrote: ↑23 Jun 2024, 12:28don't worry I don't need to look at the full specifications of Donk I just wanted to note that it plays at 800 DPI![]()
Riggedinho
as I told you I don't need to look at their specifications what you write I know.
One thing you have to take into consideration is that pro gamers have very expensive computers that run like clockwork so they can get all the quintessence of a 2000 Hz mouse
Riggedinho
For my part I am using a vaxee mouse and I have much better tracking and hitreg with 500 Hz than 1000 Hz is this linked to interference on my USB ports? is it linked to the electricity in my home (old wiring not up to standard) that's why Hertz is on a case by case basis.
I also know that when I plug in my Logitech Pro headset with the USB version I get a crackling noise in my headset so is this related?
That's why I play with the jack plug version, and I prefer it that way anyway (you'll note that lan pro players use in-ear headphones, so the audio panel is enabled in the motherboard bios, I point this out because many people in the CS:GO days played with a USB headset to disable the audio panel in the bios to avoid crazy latency, today in 2024 it's bullshit).
they pc parts are public.they dont have anything that you cant buy.Riggedinho wrote: ↑23 Jun 2024, 16:53One thing you have to take into consideration is that pro gamers have very expensive computers that run like clockwork so they can get all the quintessence of a 2000 Hz mouse
