Remove OS X 10.5 pixel clock limit
Who should I contact to get a patch written for OS X 10.5 that allows the pixel clock to exceed 165MHz? Can anyone on this forum do it? I am trying to overclock my PowerBook's LCD, but the pixel clock is locked to 165MHz, so I can't go past 85Hz. I can pay up to $600 through PayPal or Bitcoin.
Rabidz7 is a: PowerPC Fan, LCD and x86 Hater, and a Plasma/OLED/CRT/SED/FED Lover
Re: Remove OS X 10.5 pixel clock limit
Do you have some specs that show that the GPU and LCD panel in that model is capable of a higher rate? Also, what model is it? I've set up custom resolutions on my old PPC iBook in the past, though for an external monitor.
The screen was able to hit 85Hz without any issue. Refresh rates above that are blocked due to the driver limit.blargg wrote:Do you have some specs that show that the GPU and LCD panel in that model is capable of a higher rate? Also, what model is it? I've set up custom resolutions on my old PPC iBook in the past, though for an external monitor.
