Long time problem I've been facing
widow13
Re: Long time problem I've been facing
Post by widow13 » 11 Jun 2024, 15:06
spkii wrote: ↑
11 Jun 2024, 02:47
I think is more related to the UTP cable change than UPS change.. I changed my Ethernet cable and every time i move it or move the router, sensibility changes after 1 hour or 2 on the computer.
Could be, I believe it's both but more UPS side.
My PC doesn't change anymore, it's consistent.
widow13
Post by widow13 » 01 Jul 2024, 11:14
Small update. PC still working fine and haven't faced any issues since.
akylen
Post by akylen » 01 Jul 2024, 11:56
Have you tried without the ups ? or vice-versa without the ethernet cable ? to see if you can find what is making a difference specifically.
widow13
Post by widow13 » 01 Jul 2024, 12:00
akylen wrote: ↑
01 Jul 2024, 11:56
Ethernet didn't fix it but definitely helped.
After plugging the UPS my PC felt better and better every day untill it finally settled in and now everything is working perfectly fine.
So yeah UPS was the solution for me. I don't wanna experiment anymore as everything has been working perfectly fine.
cursed-gamer
Post by cursed-gamer » 01 Jul 2024, 15:20
widow13 wrote: ↑
01 Jul 2024, 12:00
akylen wrote: ↑
01 Jul 2024, 11:56
Ok, what games do you play and what ranks do you have? Share your steam profile or send me PM.
widow13
Post by widow13 » 02 Jul 2024, 04:56
cursed-gamer wrote: ↑
01 Jul 2024, 15:20
widow13 wrote: ↑
01 Jul 2024, 12:00
akylen wrote: ↑
01 Jul 2024, 11:56
Valorant. Currently due to not having that much time to play, I'm in Immortal 3.
Cyanide_
Post by Cyanide_ » 07 Jul 2024, 01:26
You're still doing good OP? BTW what ethernet cables did you buy? Cat5 ones work like trash for me, cat6 gave me instant, noticeable and permanent improvement (still not perfect). Got cat8 now but no difference, maybe because both cables are foiled and isolated already, they are also thick and hard to twist.
widow13
Post by widow13 » 07 Jul 2024, 04:55
Cyanide_ wrote: ↑
07 Jul 2024, 01:26
Yeah everything is perfect still.
I'm using a PANDUIT UTP cat6 24AWG for my PC and also bought the same one to connect my routers with each other.
I was told to not use s/ftp aka shielded cables indoors, because they create interference if not installed correctly.
Cat8 was bad for me, bad it was a "fake" one so it makes sense.
Currently ranking up after the episode change. (Immortal 300-500rr mmr)
Kipperii
Post by Kipperii » 08 Jul 2024, 04:49
widow13 wrote: ↑
01 Jul 2024, 11:14
Is your ups only for PC, or do you also plug in other electrical appliances (router...monitor...)?
widow13
Post by widow13 » 08 Jul 2024, 05:09
Kipperii wrote: ↑
08 Jul 2024, 04:49
widow13 wrote: ↑
01 Jul 2024, 11:14
UPS comes with 2 cable adapters that you can plug your Pc/monitor.
If you want to add anything else you need to buy aftermarket adapter.
I have my PC,Monitor and my routers on the UPS.
