Finally discovered the source of my unexplicable problems [WITH IMAGES]
Tuhin Lavania
Re: Finally discovered the source of my unexplicable problems [WITH IMAGES]
Post by Tuhin Lavania » 14 Jul 2024, 10:20
You mentioned enemies were prefiring you and you had no reaction time ? That problem has solved now ?
stormdak1ng
Post by stormdak1ng » 14 Jul 2024, 16:19
Tuhin Lavania wrote: ↑
14 Jul 2024, 10:20
Yes, before all competitive games was simply unplayable
Tuhin Lavania
Post by Tuhin Lavania » 14 Jul 2024, 22:32
stormdak1ng wrote: ↑
14 Jul 2024, 16:19
14 Jul 2024, 10:20
Thats insane. I will have to look into this as im facing the same problem since years now. Nothing helped. Changed isps, hardware, nothing helps. Electricity is the last thing i think about.
Fishie
Post by Fishie » 25 Jul 2024, 03:10
Hello, Is this still fixed for you? Please be honest. We (and probably you) have been stuck with this issue for years and are going crazy with no solution :cry:
Programmer, Gamer, Discord: cat.noir
stormdak1ng
Post by stormdak1ng » 27 Jul 2024, 17:12
Fishie wrote: ↑
25 Jul 2024, 03:10
Yes, in my case, that fixed all my issues. Probably this is not the problem of 99% of u guys, i'm just shared my history and maybe could help someone.
