gregtsakil wrote: ↑17 Jul 2024, 22:53
PWM is easy to see by testing with a smartphone camera.
It is not as easy to capture high PWM dimming frequency with a smartphone camera, it requires a good oscilloscope + good probe.
I think I'm narrowing it down to 3 simultaneous reasons for my problem. I know I'm sensitive to PWM. I had a ViewSonic VX3276-2K-MHD and almost threw up from the effects it had on me.
You're not alone. I dare to safely say that every human being dislikes brightness fluctuation of any kind, whether it be PWM (single-strobe / DyAC / PureXP or multi-strobe such as PWM)
So the 3 reasons I think might be, one, the angle of polarization for me and my eyes personally secondly, I have found that using my older 970 GPU was way easier for me. I tried putting a 970 to view from my 3090 and I believe the dithering is happening again but differently and the final reason might be the diference of the refresh rate.
Today, I'm getting a microscope to see if I can record my setup and have proof of my findings and share it with the world.
I hope I can see what the pixels are doing in a microscopic level,I can see with my naked eye a small pulse like wave on the colors when looking on my monitor but its not something diferent that I can recall seeing in the past and confirming its normality.
This link shows possible known triggers that people are aware of ledstrain-eyestrain-triggers , I tried eliminating one after another to come up with a final assumption.stand by that those 2 gaming monitors feel different than the one that I stated in my first post and feel more comfortable on the non gaming one.
That being said I can't really have all the info on my disposal to see the rest of the differences between them from exact panel type that each monitor uses the exact technic and materials of the matte filter that they are using and other detailed characteristics so i can see what might truly matter of the final output of the image.
Finally, it seems very weird that NVIDIA and Microsoft push all these new tech updates and don't give people full control of fine-tuning certain elements like the highly discussed topic of temporal dithering.
I believe they should use an ai algorithm that auto sets everything based on individual eye and brain of ours to have the best possible experience with our pc usage that some people spend more than 8 hours everyday in front of.
Dithering can be a eyestrain concern and I've personally had issues with static dithering (older laptop panel, 16.2mil a.k.a 6bit+FRC, not the usual 16.7m 6bit+HiFRC which should be miles better)
Sadly, barely any reviews tackle this topic due to ignorance / lack of care from people.
However, I've come across this
https://www.rtings.com/monitor/reviews/dell/s2721dgf
It seems like the Dell employs PWM backlight dimming at a frequency you may not tolerate well.
The X27q also has some kind of minimal brightness fluctuation, which may cause a trigger
https://www.rtings.com/monitor/reviews/hp/x27q
It's sadly a matter of trial error.
PWM (single / multi-strobe), motion performance (especially if low MPRT), PPI (usually, higher is better), color gamut, backlight used (SPD), coating (matte/glossy), polarization, dithering and external biological/psychological factors can all be factors which contribute to overall wellbeing of eyes.
I have a Dell g2724d and it causes me nausea and general tiredness and sick feeling.I also have a Dell g3223d and have the same isues... my 3rd monitor the Dell P3221D 60 hz have minimum or no isues at all the difference between them that I think is casusing me problems is the polararized filter that they have , the first 2 that I mentioned I cant see them though my polarized glasses and are causing me symptoms the 3rd one the Dell P3221D i can see through my p.glasses and I have no symptoms. What do you guys think ?
This, however, is really intruguing to me. There is a possibility you have issues with the polarization but nobody can be 100% sure about this, except you.
You need to trial out more display sadly, no way around it.
You could also be having issue with the KSF phosphor backlight of newer 1440p high refresh rate panels, which is a lot of people report on.
The Q24G2A, in particular, is a 1440p 165hz 24" panel which doesn't employ KSF phosphor, you could go for that (it's cheap as well)
I don't know what dithering technique it employs (it's 6bit+HiFRC, uses MV238QHM-NF0 panel) and what polarization it has, but it's a good starter imo (the SPD - spectral power distribution difference / lack of KSF phosphor might be the key to alleviating your issue)
For more information about dithering techniques, visit this (check the bottom of the page):
http://www.lagom.nl/lcd-test/black.php
Standard LED backlight (Q24G2A)
Desktop OLED could also be a viable option btw, but things such as:
non-RGB layout (causes text rendering issues), slight flicker (regardless of brightness used)
may be an issue for some.
QD-LED backlight is also an option, as it's different to usual KSF-based ones
For example: MSI MPG 274URF-QD (27" 4k 160hz), MSI Optix MAG274QRF-QD (27" 1440p 165hz),MSI G274QPF-QD (27" 1440p 170Hz)
https://www.youtube.com/watch?v=mV46Q_xs9M4
A nice source to read up on backlights used by monitors:
https://pcmonitors.info/articles/the-ev ... acklights/
Check comments here (talks about backlight used by LCD)
https://blurbusters.com/beautiful-red-p ... ion-badly/
