Pg27aqn how to make 1280x960 resolution?
barkmarkin
Thanks to a post here I messed with Cru and got ulmb2 to work disabling very , I can use it now with my 7900xtx with ulmb2 now all I got to do is set a custom resolution of 1280x960 but I can't seem to do it the osd says 2560x1440, even tho I have GPU scaling off in AMD software, I need to find timings for 360hz 1280x960 resolution, will it add too much delay using GPU scaling? Or is there any resolution and timings you use? I know this is an Nvidia display but there must be some here who are old school Counter strike players that still use the god resolution, coming from a 280hz 1080p vg279qm this is miles better but I want to optimize ir for my AMD gpu
Re: Pg27aqn how to make 1280x960 resolution?
Did you find how to create a custom res yet? if i create a lower res thn my native, it just flicker and shows artifact.
