everything changes.Also i forgot to mention i have Asus mb and i have HPET off,also keep in mind that like the guy from the video said if you have windows 10 you have to have islc running and "dpclat.exe".If you dont run it both,it will not work, also is this placebo or it works
Timer Resolution from 15ms to 1ms [Turn 60Hz-feel into 240Hz-feel on 240Hz]
JimCarry
Re: Timer Resolution from 15ms to 1ms [Turn 60Hz-feel into 240Hz-feel on 240Hz]
Hi can someone tell me what value should i put in "Intelligent standby list cleaner" (ISLC) so i am using windows 10 22H2 19045,as you see in screenshot below my "Wanted timer resolution" is set to 0,but when i do the trick from this video https://youtu.be/4VknzAMjPxE?t=484
- 1.GIF (97.99 KiB) Viewed 11193 times
- 2.GIF (212.73 KiB) Viewed 11193 times
- Slender
1709, 1803 latest w10 with good working timer and qpc based on base cpu freq.JimCarry wrote: ↑19 Sep 2024, 20:06Hi can someone tell me what value should i put in "Intelligent standby list cleaner" (ISLC) so i am using windows 10 22H2 19045,as you see in screenshot below my "Wanted timer resolution" is set to 0,but when i do the trick from this video https://youtu.be/4VknzAMjPxE?t=484
everything changes.Also i forgot to mention i have Asus mb and i have HPET off,also keep in mind that like the guy from the video said if you have windows 10 you have to have islc running and "dpclat.exe".If you dont run it both,it will not work, also is this placebo or it works![]()
yes, you need always open dpc.lat.cheker for correctly working any timer resolution on w10.
you just need find best value for your setup.
JimCarry
1709, 1803 latest w10 with good working timer and qpc based on base cpu freq.Slender wrote: ↑19 Sep 2024, 22:361709, 1803 latest w10 with good working timer and qpc based on base cpu freq.JimCarry wrote: ↑19 Sep 2024, 20:06Hi can someone tell me what value should i put in "Intelligent standby list cleaner" (ISLC) so i am using windows 10 22H2 19045,as you see in screenshot below my "Wanted timer resolution" is set to 0,but when i do the trick from this video https://youtu.be/4VknzAMjPxE?t=484
-i did not really get what you are saying.
-yep thanks, just like the guy in the video say the same.
-thanks,in your opinion is this a good one ?
- 1.GIF (114.77 KiB) Viewed 11057 times
- Slender
i mean 1607 1703 1709 1803 last w10 version where you not need make dpc.lat. open.JimCarry wrote: ↑20 Sep 2024, 00:121709, 1803 latest w10 with good working timer and qpc based on base cpu freq.Slender wrote: ↑19 Sep 2024, 22:361709, 1803 latest w10 with good working timer and qpc based on base cpu freq.JimCarry wrote: ↑19 Sep 2024, 20:06Hi can someone tell me what value should i put in "Intelligent standby list cleaner" (ISLC) so i am using windows 10 22H2 19045,as you see in screenshot below my "Wanted timer resolution" is set to 0,but when i do the trick from this video https://youtu.be/4VknzAMjPxE?t=484
IDK about value for your system.
https://github.com/SwiftyPop/TimerResBenchmark
check this, it software from OP post.
JimCarry
Thnanks man.I will try it right now.This is the graph from my result,my graph does not look like the guy from the github,and i did what he show i disable idle and then do the test but i did not understand wich one is the lowest?Should i do the test again but this i should leave open "dpclat.exe"?Slender wrote: ↑20 Sep 2024, 00:17i mean 1607 1703 1709 1803 last w10 version where you not need make dpc.lat. open.JimCarry wrote: ↑20 Sep 2024, 00:121709, 1803 latest w10 with good working timer and qpc based on base cpu freq.Slender wrote: ↑19 Sep 2024, 22:361709, 1803 latest w10 with good working timer and qpc based on base cpu freq.JimCarry wrote: ↑19 Sep 2024, 20:06Hi can someone tell me what value should i put in "Intelligent standby list cleaner" (ISLC) so i am using windows 10 22H2 19045,as you see in screenshot below my "Wanted timer resolution" is set to 0,but when i do the trick from this video https://youtu.be/4VknzAMjPxE?t=484
- hmm.GIF (233.48 KiB) Viewed 10851 times
- Slender
- unconnected
This works only on windows 11, I'm also testing this and upgrading right now.JimCarry wrote: ↑20 Sep 2024, 12:42Thnanks man.I will try it right now.This is the graph from my result,my graph does not look like the guy from the github,and i did what he show i disable idle and then do the test but i did not understand wich one is the lowest?Should i do the test again but this i should leave open "dpclat.exe"?
The benchmark works tho, I had 15ms sleep variance on win10.
I may be done for real with the input lag this time
In your case disable HPET and power saving in windows-
HPET:
bcdedit /deletevalue useplatformclock
POWER PLAN:
https://www.mediafire.com/file/39yxlxpb ... n.pow/file
in cmd: powercfg -import C:\PATH\TO\MUREN.POW
JimCarry
i disable hpet in bios asus mb it was hidden i use scewin and i uninstall it device manager,i dont have any bcedit and with "bcdedit /set disabledynamictick yes" it gets worse.this power plan has only idle disabled i think,about idle disabled i heard its bad,i have script for enable idle and disable idle before going in game.unconnected wrote: ↑21 Sep 2024, 05:51This works only on windows 11, I'm also testing this and upgrading right now.JimCarry wrote: ↑20 Sep 2024, 12:42Thnanks man.I will try it right now.This is the graph from my result,my graph does not look like the guy from the github,and i did what he show i disable idle and then do the test but i did not understand wich one is the lowest?Should i do the test again but this i should leave open "dpclat.exe"?
HPET:
POWER PLAN:
Coldplayer
What is the best way of doing this on windows 11 now? I'm using a 5800x3d if that matters. Is running set timer res not the best solution anymore?
- Slender
if w11 you can just use 1 .reg and forget it.Coldplayer wrote: ↑22 Sep 2024, 03:45What is the best way of doing this on windows 11 now? I'm using a 5800x3d if that matters. Is running set timer res not the best solution anymore?
Code: Select all
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel]
"GlobalTimerResolutionRequests"=dword:00000001if want more u need find best timer resolution value for you, check in this thread github software for find best value for your setup.
also check results in latency moon (kernel check) and dpc lat cheker.
