Floaty mouse why
Re: Floaty mouse why
Post by Slender » 20 Sep 2024, 11:07
you need start make circles inside the programm, if you start press button on desktop you get bad test.
ablemor
Post by ablemor » 20 Sep 2024, 11:10
ablemor
ablemor
Post by ablemor » 20 Sep 2024, 11:15
PCIE GEN1 :Image
ablemor
Post by ablemor » 21 Sep 2024, 09:38
Any help? Or im waiting for nothing
Hyote
Post by Hyote » 21 Sep 2024, 11:17
ablemor wrote:
21 Sep 2024, 09:38
There are so many things to consider but those graphs are horrible. First make sure you set up everything correctly, no faulty hardware, cables plugged in right, BIOS, Windows.
ablemor
Post by ablemor » 21 Sep 2024, 13:38
Why horrible? How do i know if my graphs is OK?
And my pc is ready for gaming, but i cant because flloaty mouse
Hyote
Post by Hyote » 21 Sep 2024, 14:33
ablemor wrote:
21 Sep 2024, 13:38
Mouse graphs and LatencyMon / DPC Latency Checker numbers don't actually show if your pc is okay or not but they are good to follow. The deviation should be around 20 Hz if you're using a system with basic tweaks. 5 Hz if you're using advanced tweaks on W10 or 11 and if you're on Windows 7 it can be lower than 1. Read the Calypto and AMITXV guides first.
ablemor
Post by ablemor » 21 Sep 2024, 15:04
So this is why i have floaty mouse?
ablemor
Post by ablemor » 21 Sep 2024, 15:05
And where can i see the hz? I dont know how to use this program
